    If you have the tiniest hands in the history of the universe you could probably do it with the manifold on lol. I am not that sneaky.
    I can try and sneak home for lunch and take some pics
      Daggerty
      Just take the manifold off it's not that bad.
      I have a car that can be cannibalized for parts by your car lmk if you need anything.
        Daggerty
        This was probably because of the body shop driving it around.
          E30 Heater Core is 3/4" Heater hose
            Snap saves my lunch plans hooray. Also contributes to the type2 epidemic
              i have literally 2.5 hours of day light when I get home on Thursday to get this fixed. i've never pulled an m50/s50 manifold, so I know it will be slower than that the first time around.
              thank you sir!!!!!
              like i said, i got the heater hoses on/off when I did the heater core from underneath so i'm crossing my fingers (i have big hands, btw)
              iasiphponderosahands105059181sc1.
                Manifold is super easy job Dan
                A few manifold nuts
                Fuel lines
                Throttle body
                Vac line for FPR
                ICV line to bottom of manifold
                Bosh style connector on back of mani
                That's about all I can think of
                  A few manifold nuts
                  Fuel lines
                  Throttle body
                  Vac line for FPR
                  Notes:
                  You can also just remove the two nuts that hold the injector rail in place and wedge that out of the way. No fuel anywhere.
                  You can remove the throttle cable from the throttle body instead of removing the whole thing. I think that's about a horse a piece.
                  It is quite easy though, pending your wiring harness cover setup you may have to remove the cover.
                    If you have enough wiggle room in your fuel lines do what Ben said. Mine are too short so I usually get fed up and pull them in a fit of rage
                      thanks for the tips! i know its not bad, but we'll see what happens with the bypass plans tonight. got some extra coolant hose, brass fittings and clamps from the store at lunch.
                        I can swing by later if you need assistance. Just let me know.
                          if you'd swing by at least to bring the samples, that would be very helpful!  I'm going to dive into this right when i get home.
                            Oh. Right. I changed to soft lines instead of those annoying metal ones that kept bugging me.
                            My statement may no longer apply
                              crisis temporarily averted. with some 3/4 hose and random fittings (whatever they had in stock) i was able to make a bypass section. see you all on saturday.
                                Great news! Did you bleed it yet
                                  yup, actually very easy with losing coolant from only that section of the system. also took it for a 10 min drive up to operating temp, then parked it - not going to touch it till Saturday morning for fear something else goes wrong.
                                    Daggerty
                                    https://www.zoro.com/bars-leaks-cooling-system-repair-169-oz-1150/i/G5045984/?gclid=CjwKEAjwjPXIBRDhwICRg-DbgHISJADP6QXpYvfnB2epvSgTH9PaTkeA3Zi6Ps-JeJDErqu0P8sfghoCyqLw_wcB
                                    https://m.advanceautoparts.com/p/design-engineering-quick-fix-self-adhering-tape-black-010491/10118101-p?c3ch=PLA&c3nid=10118101-P&iv_=__iv_p_1_a_214327102_g_12425515822_w_aud-496943010632:pla-298172165662_h_9018822_ii__d_m_v__n_g_x_pla_y_6201684_f_online_o_10118101-P_z_US_i_en_j_298172165662_s__vi__&utm_source=ACQ&utm_medium=cpc&utm_campaign=PLA&utm_content=shoppingcampaigns&gclid=CjwKEAjwjPXIBRDhwICRg-DbgHISJADP6QXpXlZslt1objhw53nxd4cC38C_2Mx81rPsRjz7zEofwRoCjyDw_wcB
                                      I keep that hose repair tape in my on-board tool kit. It saved me once when I was in high school.
                                        I didn't know it could be used for that...
                                          On second thought, being DEI its probably for exhaust leaks and header cracks. I meant the radiator hose tape
