580 Posts 27 Posters 0 Views 1 Watching
    Is that coolant spritzed all over there? Heater hose spring a leak?
      Can you at least pinpoint the source of the leak? Or does the manifold have to come off
        uh oh. just got home, smelled some coolant in the last mile and the temp gauge was above half. #saturdayinjeapardy
        Ask Ben if you can borrow his temp gun
        Yeah, you need to make sure that it's actually overheating and not just the cluster. Chances are it's not actually overheating. Did you check the temp with a gun yet to make sure it's overheating? Because it may be a loose nut on the cluster. Did you verify the temp yet? I would probably hit it with a temp gun to ensure that it's actually overheating.
          Nooooo, maybe it wasn't bled properly and got hot?
            Pretty much anytime you want to do something on these cars the manifold has to come off
              That spray pattern is odd. Coolant spider hose dealio may have split?
                lol @ temp gun. the car did not overheat at all. was between 1/2 and 3/4 mark when I got home.
                got up early and looked at it before work today.
                correct.  spider hose split @ the heater core inlet pipe.
                i ordered one (and intake mani gaskets) with overnight shipping, but i don't think I'll have time to dive in and get the manifold off to replace it.  without removing the manifold, i SHOULD be able to pull both heater core hoses from below and just connect them together (temporarily bypassing the heater core) to get me by for Saturday. i was able to pull them when I replaced my heater core, I just don't know how much room/slack they have for connecting them together.
                if anyone knows what internal size those hoses are off the top of their head, it would help on my lunch time quest for a fitting at the hardware store. 5/8" or 3/4" is my guess.
                  If you have the tiniest hands in the history of the universe you could probably do it with the manifold on lol. I am not that sneaky.
                  I can try and sneak home for lunch and take some pics
                    Just take the manifold off it's not that bad.
                    I have a car that can be cannibalized for parts by your car lmk if you need anything.
                      This was probably because of the body shop driving it around.
                        E30 Heater Core is 3/4" Heater hose
                          Snap saves my lunch plans hooray. Also contributes to the type2 epidemic
                            i have literally 2.5 hours of day light when I get home on Thursday to get this fixed. i've never pulled an m50/s50 manifold, so I know it will be slower than that the first time around.
                            thank you sir!!!!!
                            like i said, i got the heater hoses on/off when I did the heater core from underneath so i'm crossing my fingers (i have big hands, btw)
                            iasiphponderosahands105059181sc1.
                              Manifold is super easy job Dan
                              A few manifold nuts
                              Fuel lines
                              Throttle body
                              Vac line for FPR
                              ICV line to bottom of manifold
                              Bosh style connector on back of mani
                              That's about all I can think of
                                A few manifold nuts
                                Fuel lines
                                Throttle body
                                Vac line for FPR
                                Notes:
                                You can also just remove the two nuts that hold the injector rail in place and wedge that out of the way. No fuel anywhere.
                                You can remove the throttle cable from the throttle body instead of removing the whole thing. I think that's about a horse a piece.
                                It is quite easy though, pending your wiring harness cover setup you may have to remove the cover.
                                  If you have enough wiggle room in your fuel lines do what Ben said. Mine are too short so I usually get fed up and pull them in a fit of rage
                                    thanks for the tips! i know its not bad, but we'll see what happens with the bypass plans tonight. got some extra coolant hose, brass fittings and clamps from the store at lunch.
                                      I can swing by later if you need assistance. Just let me know.
                                        if you'd swing by at least to bring the samples, that would be very helpful!  I'm going to dive into this right when i get home.
                                          Oh. Right. I changed to soft lines instead of those annoying metal ones that kept bugging me.
                                          My statement may no longer apply
