E21 Project Thread - Part 2
Got his number by chance?
Started cutting out the old seat mounts in order to make new ones lower in the car for the e30 sport seats. Otherwise they would have sat too high. Also preparing to do some floor pan surgery as well.
Last night I also made an adapter for my m50 tps to use with megasquirt.
Its all good. The one I made does the job just fine. Thanks tho. Plus at the time you sent it, I didn't need the adapter as I was using the tps on my m10 turbo setup.
These will hopefully be in my hands in the near future ....
Havent updated this is a long time. After finally getting all my stuff welded by Dan the muffler man, I got the exhaust all buttoned up, charge piping installed, fuel hoses to fuel rail on, coolant hoses mostly on, vacuumed lines routed, started cutting out the rustly floors and also got the driver side seat mounts in and welded. this is the part of the build that really gets ya. A lot of small stuff that nickel and dimes ya till its finally done. It'll all be worth it tho
Finished up connecting random coolant and vacuum lines. Started getting the wiring situated with soldering in the IAT sensor and doing a little modifying for the wideband, but ran into a problem. Turns on the o2 sensor plug and the oil pressure switch plug were cut off of the e30 harness I got. So I now have to cut open the harness to dig them out far enough to extend the wires. There goes my nice clean looking wiring harness.
Anybody have a pic of where the oil pressure switch wire comes out of the harness, so I can search for any sign of what's left of that wire on mine? I found where the o2 sensor wires were cut.
Got the o2 sensor wires pulled, extended and soldered up, cleaned up wires under the dash behind radio, mounted the megasquirt ECU under glovebox area along with wideband controller. Also wired up the IAT sensor.
Next is adding engine oil, coolant, trans fluid, running the boost line for Megasquirt, siphoning out old gas and refilling with fresh gas and give it a test start.
Hopefully tomorrow after going to brewers game or this week.
Friggin rights!
Well it's true. You better have it running
Hit the jackpot on oil! Couldn't resist the price!
O'reilly's currently has Valvoline Max Life 20w50 synthetic blend for $1.07 a quart!
Originally over $6 a quart. The guy at the O'reilly I went to thanked me for taking every last bottle they had, lol. -
Originally over $6 a quart. The guy at the O'reilly I went to thanked me for taking every last bottle they had, lol.Is this every O'Reillys?
Seems like it since its on the website
