  3. Services Offered/Wanted
  4. BMW Bushing Puller Tool Needed
37 Posts 9 Posters 0 Views 1 Watching
  • BenDemB
    BenDemB
    BenDem
    It might... My guess it would depend if the bushing is seized onto the bolt / frame of the car.  Then again, if it's not a vert, you could probably remove the bolts and then get a saw in there to remove whatever the tool didn't remove.
    It's worth a shot... worst case, you'd just pull the subframe anyway.
    But... If your subframe bushings are that bad, your trailing arm bushings are probably shot too.  You'd probably save time by removing the subframe and doing both jobs at once.
      Pm sent about borrowing the tool. Holding on to a little optimism that the bushings will come out with little drama. We'll see.
        Well borrowed Ben's tool, and no success for me. Puller and heat and all I accomplished was bending the outer metal lip of the subframe bushing. Short of pulling the subframe which I really don't have time or the inclination to do, any suggestions on options? I was able to knock out the long bolt. Thanks.
          It is a pain but I have used a drill bit to destroy as much of the rubber as I could to get the center of the bushing out and then using a sawzall to cut the outer sleeve so that it collapses on itself and falls out.  I did this when I replaced my e36 RTABs.
            Thanks. I used a drill and hole saw to clear most of the rubber. Metal center though looks to be stuck to the body. The outer sleeve is stuck to the subframe tube. Car is on jack stands so not enough height to use the sawzall. Any other suggestions ? Starting to see why folks drop the subframe to do this.
              The center should just be held in by the rubber.  Could you get a hacksaw in there?  The blades are much smaller.  As soon as the outer sleeve splits it will fall right out.
              • BenDemB
                BenDemB
                BenDem
                When I installed my new bushings, I put some anti-sieze on the top of the metal sleeve (on the bushing).  I think I remember seeing somewhere that they can get corrode to the frame?
                Maybe that's what happened to yours?
                  Yep. Tapped and inserted a 5/8 bolt into the center piece. Tried to hammer it loose from the top but no luck. Smacked the bolt from the side and got it loose but of course with the aluminum stub broken off on the body. Drilled and dremeled this out. Chisel Dremel and vise grips to work out the sleeve.
                  Drivers side was a repeat of the same issues. Tried the tool just for laughs with no luck. Back to the drill. Center came out easier but the outer sleeve was worse. Ended up buying a HF air chisel to get it out. Still have some aluminum residue from the core left in the body that I need to ream out. One more trip to the hardware store.
                  Moral: cool tool but for a Midwest e30 with approx 250k and a lot of winters too much for it
                    Done. Bottle jack and pipe cap to get the bushings 3/4 in and puller for the last 1/4. Put the bushings in the freezer overnight, heat gunned the tube, coated bushings in dish soap. No more clunk on shifting.
                    Sending out the tool to Chris this afternoon. Looking forward to a success story!!
                      Nice! Glad it worked out for you.
                      • BenDemB
                        BenDemB
                        BenDem
                        I was wondering.  The underside of my e30 is ridiculously clean, being a low-ish mileage Florida car.
                        Here's hoping Chris has better luck!
                          280k miles on the 540i... We'll see boys
                          • BenDemB
                            BenDemB
                            BenDem
                            Just curious,  how'd it go?
                              See thread here: http://www.wibimmers.com/board/index.php?/topic/2472-my-new-1995-540i6/page-5#entry47223
                              Long story shot the E34 bushings are much bigger than E30/E28 ones so the tool didn't fit.
                              Whoever requests the tool next I can have it shipped out to unless you want it back Ben.
                              • mkoeppM
                                mkoeppM
                                mkoepp
                                I just ordered new bushings and should have them in a week. I have never done it but I have access to a press and will be removing the sub-frame. Is there a need for the tool if I do it this way?
                                  Nope id use the press to push old out and new in, much easier and faster.
                                  • mkoeppM
                                    mkoeppM
                                    mkoepp
                                    That is what I am hoping. Going to start this project next week.
