1987 325e. Eventually Boost+M50 Swap
DP
Care to elaborate earl?
Double penetration?
Any suspension plans?
its too cold for paint.
-22 is merely Balmy.
Or cut the bumpers off and make rally bumpers with a light bar for the front I've already got ideas fort e28 which is bumperless now
Do the "i" head swap and keep the eta bottom end for sure! I would highly recommend to replace the valve seals while the head is off. Can you replace the rod bearings while the crack is still in? If so, do that as well.
I have a 524td manifold if you're interested. You'll have to source some adapters to make it work. A guy on r3v just sold some.
I would keep the metal bumpers. The rear sits a little higher so it is more aerodynamic because racecar.
What are you going to do for a tune?
How much are the adapters going for?
I'm not sure. He took the post down
I'm not sure. He took the post down.
The 524d manifold would be awesome if its cheap enough
Pics of this?
I PM'd the guy that had the adapters for sale asking where he sourced the part. I'll let you know what he says.
I also sent you a PM
Due to the suggestions of a few forum members I think I am going to M50 swap rather than do the 2.7i conversion. The m50 swap has been covered multiple times and in reality it shouldn't be too much more work. Parts are more readily available and it will be able to handle the boost a lot better due to the fact it has twice as many valves. My bottom end also has 280k on it so I'd rather not push my limits.
Edit:
Could someone change the build title for me?
M50) said:
