  4. 1987 325e. Eventually Boost+M50 Swap
e30325e2.7iboostredeta
112 Posts 17 Posters 2.4k Views 1 Watching
    Snap ( I ❤ M50) said:
    its too cold for paint.
    -22 is merely Balmy.
    • RamRod E28R
      RamRod E28R
      RamRod E28
      Or cut the bumpers off and make rally bumpers with a light bar for the front I've already got ideas fort e28 which is bumperless now
      1988 BMW 528e - Need parts?
      1996 Mazda Miata (SOLD!!!)
      1996 BMW 325i (Donor car)
        Do the "i" head swap and keep the eta bottom end for sure!  I would highly recommend to replace the valve seals while the head is off.  Can you replace the rod bearings while the crack is still in?  If so, do that as well.
        I have a 524td manifold if you're interested.  You'll have to source some adapters to make it work.  A guy on r3v just sold some.
        I would keep the metal bumpers.  The rear sits a little higher so it is more aerodynamic because racecar.
        What are you going to do for a tune?
        • L
          L
          Laishes
          Going to tune on megasquirt hopefully! What's the benefit of the 524d manifold? I haven't done extensive engine work before only replaced headgaskets and done timing a few times so I'm unsure about the valve seals and bearings
          • L
            L
            Laishes
            How much are the adapters going for?
              I'm not sure.  He took the post down
              • L
                L
                Laishes
                DrLeadFoot said:
                I'm not sure.  He took the post down.
                The 524d manifold would be awesome if its cheap enough
                • L
                  L
                  Laishes
                  Pics of this?
                    I PM'd the guy that had the adapters for sale asking where he sourced the part.  I'll let you know what he says.
                    I also sent you a PM
                    • L
                      L
                      Laishes
                      Due to the suggestions of a few forum members I think I am going to M50 swap rather than do the 2.7i conversion. The m50 swap has been covered multiple times and in reality it shouldn't be too much more work. Parts are more readily available and it will be able to handle the boost a lot better due to the fact it has twice as many valves. My bottom end also has 280k on it so I'd rather not push my limits.
                      Edit:
                      Could someone change the build title for me? :)
                      • L
                        L
                        Laishes
                        Is this a correct parts list? what else will I need?
                        someone said:
                        m50 longblock. + all accessories (sensors, intake manifold, etc etc.). preferably non-vanos but either will work. Ideally out of a E34 525i (I need this oil pan for clearance). I don't need a transmission or exhaust; I will be reusing my Getrag 260.
                        Special transmission mounts + bracket. GunMetalGrey might sell these?
                        e36 engine mount arms with e28 535i motor mounts (should I buy these new online or?)
                        I can reuse my e30 driveshaft because I will be reusing my g260 trans?
                        late model e30 coolant expansion tank 88+
                        brake booster? or relocate?
                        http://www.e30dohc.c...e=Brake_Booster
                        E36 steering rack +???or is it necessary?
                        And some misc items:
                        325es/325is/318is:
                        Sand Beige Sport Seats (in good condition, will give more money if they are heated.)
                        E36:
                        Sand Beige Vader seats (in good condition, will give more money if they are heated.)
                        325es:
                        Red Bumper Front Valence
                        Note:I will not need the following if I got ahold of an m50 from a e34.
                        E34 525i oil pan, dipstick tube, dipstick, oil pickup tube
                        E34 525i wiring harness
                        E34 throttle cable
                        • L
                          L
                          Laishes
                          Uhhhhhhhh... janky!!!
                          Headers from??
                          Zinnoberrot!
                          Theres my crank case breather hose? lol
                          This is supposed to be one hose...
                          Don't even know.. Don't even ask, aparently thats the window washer thingy? would explain why its not working....Ahh! rust! I'll have to have that removed in the near future.
                          • JeffJ
                            JeffJ
                            Jeff
                            looks like the work of a ver knowledgeable previous owner. i think the radiator hose is my favorite.
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                            • L
                              L
                              Laishes
                              I actually bought the car off a guy named Jeff..... He's giving you "jeffs" a bad rep man. ;)
                              He said it was an emergency fix because the hose cracked in the middle. :D  :D  :D
                              • JeffJ
                                JeffJ
                                Jeff
                                damn jeffs always screwing things up. what is his excuse on everything else??
                                1976 530i e12
                                1990 325ix e30
                                1992 325i e36
                                1995 740il e38
                                2001 330xi e46
                                ^More to come :)
                                • L
                                  L
                                  Laishes
                                  Didn't have time or was too lazy!
                                  I picked the car up for 1400... What did I expect?!
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    still a great deal i love finding previous owner fixes for a problem they alway make me laugh
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                      Edited the title even though I'm disappointed gonna do a crab snail build :(
                                        Looks like I will be the lone ranger with the only force-fed M20 around here afterall.
                                        So that PCV hose doesnt connect to the valve cover then? that would make for a massive vac. leak and cause the car to run like potatoes
                                        • L
                                          L
                                          Laishes
                                          I'm sorry snap :( I just don't think its worth it to do the head swap when I could probably source the m50+parts for only a couple hundred more
                                          I don't know where that hose goes to I'll go take a look right now
