  4. New ride! 89 e30 vert
summertime rage
141 Posts 18 Posters 1.6k Views 3 Watching
    Ramze46 said:
    you need these wheels for your e30
    Ah, yes,  MiM 1900's
    I like those, they remind me of Alpina wheels, what are they?
    MiM 1900's
    Ramze46 said:
    snap should know they look oem to me
    They are MiM 1900's
    CYoung said:
    He doesn't know everything!
    Very true! but I do know how to multiquote.
      If anyone spots a set let me know, they look sweet.  And a little different than everyone with basketweaves.
        Got the pedals in.
        Adjusted valves, and installed exhaust manifolds with new gaskets, not sure why they are different, they were in the same packaging from Victor Reinz.
        Also I love stickers!!!!
          Got started tonight around 9,  Fedex package came, it's Christmas!!!
          Replaced cam seal and o-ring, and installed water pump
          Valve cover gasket and rocker arm shaft plugs replaced.  Top end looks very clean, this car has been taken care of over the years.
          Timing belt on.
          And timing belt covers installed.
          Now I had better go to bed so I can get up at 5am for work tomorrow, I am super excited to drive this thing, the only time I have driven it is in reverse a half mile from the storage unit to my house (Mike you should try to post the video).
            Bring it to the e30 picnic!
            • RamRod E28R
              RamRod E28R
              RamRod E28
              Been trying my phone is being a typical iphone and wont let me send vids to youtube i can try to email you the vid or i can send it to someones smartphone maybe
              1988 BMW 528e - Need parts?
              1996 Mazda Miata (SOLD!!!)
              1996 BMW 325i (Donor car)
                Got alot done on Monday, New engine mounts.  Lowriders guys, you can gain a quarter inch of oil pan clearance by replacing your junk motor mounts.  My engine was pretty much sitting on the steering rack.
                New rear main seal and all cleaned up.
                Different sizes of PVC fittings work awesome as seal drivers.
                New cap and rotor, old one was pretty rough, thanks Nick!
                My helpers for a while.
                Then Mike and Ben came over and we really moved.  Head cleaned up and ready for the intake.
                Transmission in.  That looks so much nicer under there, Mike and I took the transmission to the quarter car wash and pressure washed it, not as nice as Ben's but much better.
                How she sits right now, after work tonight I will get a few more things buttoned up.  I need to replace the muffler and just want a dual in/dual out, weld in one, any recommendations?
                  bfinley
                  No yours looks better because it's in the car ^^^ can't wait for dirty 30 burnout a
                    It is getting close, not much time to work on as I am working 10hr shifts at work but I have Sun/Mon off.
                    To do:
                    Tighten drive shaft to differential bolts
                    Replace fuel filter
                    Weld muffler onto my cat back pipes and install (Thanks Andy! it looks great)
                    Install new front control arm bushings
                    Install radiator and hook up coolant hoses
                    Replace battery clamps, tightening bolts are seized up
                    Install air box and AFM
                    Change transmission fluid
                    Fill engine oil
                    Fill coolant
                    Turn key!!!
                      Exhaust is done, Control arm bushings are pressed into the lollipops, air chisel works awesome for removing the old ones.  I forgot on the list that the clutch needs to be bled too.  Tomorrow is the day hopefully.
                      • RamRod E28R
                        RamRod E28R
                        RamRod E28
                        Really think you need to one up this dude noaw!!!
                        • RamRod E28R
                          RamRod E28R
                          RamRod E28
                          exhaust vids then!
                          • RamRod E28R
                            RamRod E28R
                            RamRod E28
                            I think ur e30 is due for this
                              Noon update.
                              Replace fuel filter, pretty sure it's been on there for 25 years.
                              Fab mount for exhaust to manual trans.
                              Bleed clutch and brakes, fluid is extremely disgusting
                              Fill engine oil
                              Fill coolant
                              Turn key!!!
                                Noon update.
                                Fill engine oil
                                Fill coolant
                                DO BURNOUTS
                                Turn key!!!
                                Added the most important step
                                  This is awesome, Keep it up man!
                                    You talk a big game. Still waiting on your burnout vids dood! :P
                                      Got a lot done yesterday, I will get some pics up later.
                                      Bleed clutch and brakes, fluid is extremely disgusting, ran out of fluid before I got to the clutch, Flushed a quart through the brakes though and got a lot of junk cleaned out
                                      Change differential fluid
                                      Fill engine oil
                                      Fill coolant
                                      Install clutch switch and make wiring splices.
                                      Turn key
                                      Burnouts!
                                      • ClassEC
                                        ClassEC
                                        ClassE
                                        Looking good!!! Reading through your list has reminded me of some things I should do.
                                        Aaaannndddd...... In for burnout video.
                                          I shouldn't have any trouble doing a one wheel wonder with the 4.10 gears.  Too bad this one didn't have an LSD, or maybe it is just worn out?  Tires turn opposite directions when off of the ground.
