686 Posts 32 Posters 8.9k Views 3 Watching
    Fantastic. Great shots.
    And great e30
    • ClassEC
      ClassEC
      ClassE
      Thanks! ;)
      I've been hearing a slight whining/grinding noise from the rear the last couple times I drive it. Sounds like it's coming from the PS rear, doesn't get loud enough to hear until 15+ mph, is constant (doesn't change under braking or cornering) and is fairly high pitched (not metal-on-metal but does have a dragging metallic sound).
      Pull the rear brakes off last: plenty of life on shoes and pads, shoes are functioning properly and are fully retracting when ebrake is released. No play up/down or left/right out of hubs - but hard to tell just by yanking on studs.
      Only thing I could find out of the ordinary was some uneven wear on the rotor faces (just some light grooving - nothing I'm concerned about) and the following on the PS rear pads:
      See the "lines" on the pad with wear sensor that run perpendicular to the rotor rotation? No idea what they're from - possibly a bad pad?
      I was planning to do rotors/pads all around with good everything about mid summer, cash flow is alittle low right now. Maybe I'll have to do them sooner then later?!?
        I'm sure the grooving on the pad matches the grooving on the rotor face, a little bit shouldn't be a problem.
        • ClassEC
          ClassEC
          ClassE
          I agree - but what are thoughts on the thin perpendicular lines on the top pad in the pic above? Crappy pad?
            If you don't mind sharing, how much did the paint job run you? looks like it turned out pretty good.
              It doesn't look like it is cracked or anything, not sure about those marks, I would just run it until you can do the whole brake job.
                I think the price was very reasonable. IIRC he only had the valence, front bumper, passenger fender, passenger quarter, and passenger door painted. The rest is original=)
                • ClassEC
                  ClassEC
                  ClassE
                  They only painted the passenger side and front, drivers side and rear are all original paint. Paint shop was alittle under $2000, and I supplied all the replacement body panels needed (PS door, fender, front valance).
                  • ClassEC
                    ClassEC
                    ClassE
                    I also had them prep and respray the underside of the hood in preparation for bay work next winter. The entire door needed to be replaced and internals swapped over - which apparently was a pita. Both of those added a bit to the cost.
                    When it comes to paint work - I'll only have Inline Autobody in Oshkosh touch my stuff. The owner Kurt has been doing stuff for me for years and does great work.
                    • ClassEC
                      ClassEC
                      ClassE
                      Well.... Might have found the culprit for my slight grinding from rear. Not sure:
                      Rotated wheel ends from both sides - couldn't hear anything troublesome, only noise was a slight "whine" from diff. So put new pads in passenger side and reassembled - turned over to same results. Put rotor back on drivers side and turned over by hand. "GGRRIIINNDDD"
                      Ruh-oh
                      Checked to make sure ebrake was fully disengaged, rotated again and got the same sound. Removed rotor and found these on inside of rotor:
                      2 separate cracks, about 60 degrees apart. I swapped rotors side-to-side and got same grinding.... So not sure if it's the issue.
                      Shoes are seated firmly against backing plate, springs seem to be under good tension, and brake appears to be operating normally. There was some heat cracking on shoes - but not excessive wear.
                      Thoughts?
                      Don't have a lot of experience replacing shoes/springs, so will have to do some research in the AM.
                        This would look nice under the hood=)
                        • ClassEC
                          ClassEC
                          ClassE
                          I like the idea of keeping with an M20, not sure if I wanna go big cam/ITB's or boost tho.
                          I do love the sound of a monster cam at idle....
                            I love the sound of wide open ITB's=D
                              That ITB setup would be fantastic!  That car must be horridly slow or obnoxious to drive though
                              • ClassEC
                                ClassEC
                                ClassE
                                How do you figure?
                                  Must have a hole in the floor for Fred Flintstone action.  There is no coolant hose from the overflow, and no cap/rotor/plug wires.  Also if it did somehow run, it would just idle along with no throttle cable.  I do however like the gold brake lines.
                                    The M20 is quite well optimized out of the box and in my opinion the two areas where people go horribly wrong on NA M20 builds is changing to a piston which does not match the squish area of the combustion chamber and not taking advantage of pressure wave tuning on the intake manifold.
                                    -short runner length/no plenum
                                    -low air velocity at low rpm with itbs
                                    -large camshaft required to match intake selection
                                    -high compression pistons required to keep static and dynamic compression ratios happy due to large cam
                                    -pistons without the proper squish area due to the requirement to have high compression as well as valve clearance due to large cam
                                    It would be like disabling the VTEC system on a honda. It's removing the secret sauce that makes it perform the way it does.
                                      Well that too, if you want to get into the details.
                                        you cant be a bastard e-thug forum troll and not backup your opinions with a little bit of food for thought.
                                        • ClassEC
                                          ClassEC
                                          ClassE
                                          I have a burning hatred of the M20 intake manifold, if I keep that platform it will have to be changed to something (SRI, ITB's, ANYTHING else). I'm open to a lot of ideas... Just not keeping that ugly ass mani.
