  4. '88 E30
'88 E30
savebigmoney
    Order the febi slave and guibo. What clutch did you decide on?
      Haven't really decided
        Just ordered:
        Core support
        Mishimoto radiator
        Bimmerworld radiator hoses
        Clutch/pp/fw (comes with release bearing, pilot bearing, hardware)
        Slave cylinder
        BMW coolant
        Still to order:
        98 m3 Driveshaft
        E30 csb
        Flex disc
        O2 sensor
        Trans fluid
        Diff fluid
        Shifter rebuild kit
        Shit adds up quick
          Christmas in July
            what clutch did you decide on?
            and hey I gotta ask how much did you get your s50 for? I see s52's on car part for 1500$ and it makes it very tempting. an extra 1000$ nets me a good chunk of NA hp but I'm not sure if buying a very used s52 is a good idea ha.
              I went with the gripforce stage 2 clutch. Read some good reviews on bimmerforums of guys being skeptical, but they had good things to say. After I put it in and beat on it for a while I'll post my review as well. It's a cheap alternative at this point. If I have to tear it out in a year, lesson learned I spose.
              I picked up the s50 with great compression, full harness, zf trans and DME (literally everything to swap) for $1450. Some stuff I won't be using cause I was already 24v. But now I have spares which is nice
                Coolant, febi clutch slave, core support and radiator have showed up
                  removable core support using stock core support?
                    Yes sir
                      The CSB is mounted on the e36 DS on the opposite shaft than the e30 DS.  Just make sure the offset side is mounted the same as the e30 DS was.  This sounds confusing but when you see it in front of you and side-by-side it makes perfect sense.
                        Thanks for the heads up. Still on the fence about where to order from. Wholesale something or other is where I'll most likely go.
                        As far as shift stuff goes
                        I was thinking to just order the condor kit with the short knob (?) the uuc evo3 with dssr is like $460. I've been told it's worth it, but idk. Rebuilt stock stuff with Delrin would still be better than nothing I suppose
                          I'm not sure what you are running for engine and trans mounts, but I built this floor mount shifter like the AKG one and MAN it's amazing. It's not finished in this picture, but I have a solid brass handle on it now and it's killer.
                          This is in my daily beater.
                            I forgot about the best part. You get to delete the bitch clip!!! Super easy install.
                              Everything's out of the car right now, so the bitch clip won't be that big of a bitch haha
                                But it won't stay that way forever right?
                                  The engine and trans will come out before the shifter ever gets loose again
                                    Okay, anyways. I'm just saying it's an epic setup and I'm never gonna miss a gear again. Amazing to drive with.
                                      I believe it! I just want a decent shifter feel. The car has other areas that need attention first lol. Like putting it back together
                                        I have the uuc w/dssr. The dssr is awesome but I would rather have a floor mount shifter. Don't get me wrong, its a nice product but I don't really care for a shorter throw.
                                        Sent from my potato phone
                                          I like mine a lot. But I've never shifted a floor shifter.
