fyi, my tank vent line with filter to the atmosphere doesn't give off any odor. i applaud you for worrying about nature, and all that.
Dropped off the oil pan to have the baffle welded in this morning. Once I get that back, it can be bolted in, and the engine will come off the stand for good (hopefully). I have a gripforce stage 2 clutch (sprung hub) and chromoly lightweight flywheel ready to install, and then the transmission can be mated up with the engine and the whole shebang can go in the car!
For those of you 24v people, is it easier to install the engine and trans from the top or to remove the subframe and install from underneath?
of all the engines i've pulled from e30s, a 24v isnt one of them, despite me owning two. i still have an opinion though, this is the internet, after all.
does your hoist have a leveler? the engine will have to go in at a steep angle from the top. a trick I've read is to air out the front tires and jack up the rear of the car to reduce the angle of the dangle.
I have a hoist but no leveler, wouldn't be hard to get one though. The other issue I have that I just realized is that the garage door opens over the engine bay so I can't hoist things super high, maybe not the best layout for this... that may force a bottom entry. How steep of an angle are we talking? Like more than 45 degrees?
https://youtu.be/Z3ncelZ0PBc?t=1m5s
no load leveler, but some helping hands instead. looks like they had to get the hoist about 8' up in the air (hence, pulling the car outside). let me know if you want help!
I remember closing the garage door part way to get the engine hoist high enough when doing mine and brians engines. Food for thought.
Thanks for the tips guys! I'll have to look and see what kind of space I have. Pulling the car into the driveway could block one of the people who lives in the house from getting their car in/out of their parking spot so that may be a problem... I'll have to investigate and take some measurements. I just picked up the welded up oil pan so I can get back on this as soon as I get back!
joe!!! https://www.r3vlimited.com/board/showthread.php?t=423153
Ugh... why do these things always have to come up when I just bought something else! That's a pretty decent price, especially since it includes shipping
Haven't had much time to work on this, but was able to sneak away for an hour today. Got the oil pan back from the welder a week ago, mounted it up with a new gasket for good today:
Then went to test fit the power steering pump:
Damn. The feed line to the pump contacts the oil pan, causing the outer mounting bolt to be misaligned by around 3/4". I haven't heard of anyone having pump mounting issues with the e34 oil pan, so I checked realOEM, and found that BMW has a different part number for the RWD and AWD e46's. You can apparently use both the Luk LF-20 and LF-30 pumps (I have the 30) with this swap, and I would be very surprised if there were actual differences in the pump itself between the different drive types. You can't buy the brackets separately, so I'm thinking the mounting brackets place the pump in a slightly different spot, hence the different part numbers.
If I can't get a cheap set of brackets from a rwd car the cut/bend/weld route will be the best bet. The front bracket would be really simple, the rear has a weld nut for the outer bolt, as well as a 90 degree flange that will have to be adjusted to compensate for the rotation of the pump assembly relative to the block.
I did some more research and based on pictures comparing my brackets with the brackets from a RWD M54 (and E36 M52, same part), it looks like those will rotate the pump up closer to the underside of the alternator and give me the clearance I need. This picture from ECS (sorry for the upside down comparison) shows the top bolt of the pump much closer to the inner mount hole, compared to my picture above:
Redrill the one hole in the mounting bracket?
yeah, this seems like a no-brainer. if the bolt ends up too close to that side flange to get a wrench on it, you could switch to a socket cap bolt.
The problem is the rear bracket, since that outer bolt just passes through the oil filter housing casting and threads into a second bracket on the back side of the pump.
Modifying that bracket to match is definitely doable, its just more than drilling a hole since the weld nut either needs to be moved or a new nut welded on, and then once the pump is rotated that flange needs to be cut and welded at the correct angle to mate up with the corresponding hole in the block for that bolt. I think the cleanest solution is just to get the right brackets from a RWD e46 or m52 e36.
Haven't made any progress on the car in the last few weeks between too many things to do and not enough motivation, BUT I finally ordered a swap harness! This will integrate everything from the gauges to the fuel pump relay, as well as provide an OBD2 port to read data and codes from the ECU and flash new partial tunes without pulling it out of the car. This should greatly simplify the electrical side of things once the motor is in the car. It isn't cheap, but it will save me huge amounts of time over sourcing all the needed pigtails from various e46/e39 body harnesses and getting everything right when wiring it up. I am hoping to spend more time on this again soon, with the goal being having the engine and trans in the car by the end of August.
Swap harness arrived! The only additional thing I needed to source was the cable running from the B+ junction on the firewall to the positive starter terminal from an m20 car, as the one on a 318is is part of the engine wire harness.
I decided that the power steering pump brackets can wait until the engine is in the car, so I skipped that for now. Last thing to do while it was on the stand was install the e34 m50 dipstick after a few minor modifications to it's bracket. With that done, I removed the engine from the stand for the last time and started fitting the Gripforce chromoly flywheel and stage 2 clutch (lightest duty option with a sprung hub). However, I was unprepared and didn't have my torque wrench with me for the flywheel bolts, or the appropriate grease for the clutch fork/throwout bearing/etc, so that's where I left off on that.
I decided that given the overhead room and lack of space in the driveway outside my garage, that the only way this engine is getting into the car is through the bottom. I pulled the front subframe and installed the Condor UHMW swap mounts. All that's left to do in the bay is remove the m42 coil pack brackets on the passenger side strut tower and it will be ready for the engine.
After a few very busy months this summer, I was able to get a few nights of working on this after work over the last two or three weeks. Things are finally moving again!
I removed the m42 coil pack mounting brackets from the strut tower and inner fender. I also cleaned up some surface rust on the washer tank mount and primed all the bare metal. Had a bit of a mishap on the inner fender and ended up popping two holes where the welds were.
I plugged the holes with some flat steel plugs. Because I deleted ABS I also plugged the holes where the wheel speed sensors passed through on both sides. I like these metal plugs because you can fold the ears flat on the back and lock them into place, they sit flush, and can be removed any time you want the hole back.
I also sprayed a coat of undercoating on the backs to seal everything up.
With the engine bay ready to go, I got to work on prepping the engine. Pilot bearing installed, Gripforce chromoly flywheel cleaned, installed with loctite and torqued to spec:
There was a lot of conflicting information on which way to install the Gripforce stage 2 (sprung hub) clutch disk, but this orientation seemed to be the majority of responses. Hopefully that's correct...
Pressure plate installed with loctite and torqued.
Got everything sorted on the transmission side as well with a new clutch fork, quality throwout bearing, and a steel pivot pin from an e39 540i.
I didn't have a furniture dolly to roll the engine under the car with the transmission attached, and didn't have enough room to hoist the engine into the car with the garage door open, so I had to take a bit of a convoluted route... Here is a bit of a DIY if you're in this exact scenario with the same tools:
Step one: Hoist engine into the bay from the side with the garage door closed
Step two: Lower the engine as low as it can go without sitting on the arms of the hoist, support weight with engine support bar
Step three: Open garage door, rotate hoist to front of car and lower engine all the way through the bay onto the floor:
Step four: Move transmission underneath the car and struggle to mate it up with the engine, succeeding eventually:
Step five: Realize you're an idiot and forgot to grease the clutch splines, pull it apart and apply light coat of moly grease. I have never done a clutch on my own (last time I helped with one was at least 5 or 6 years ago at my old job)... everything I read said use a very light coat to avoid having grease flung into the clutch. Hopefully this is enough.
Step six: Reinstall transmission, install starter, realize it's after midnight, leave it at that and go to bed.
Step seven: Return about a week later, full of energy, and lift engine into place and reinstall front subframe underneath engine.
I had to remove one of the plastic clips holding the passenger front brake line to the firewall as well as a wire harness mount from the back of the head to get the engine to sit back far enough. I also had a bit of a fight with the condor swap mounts to get things to line up properly. They didn't seem to sit flat despite putting them in various different orientations. I ended up finding a note on a forum post somewhere from them stating to leave everything loose, and tighten down the bottom nuts on the engine mounts one turn at a time (alternating sides) to center the engine, then trans mounts, and then top nuts on the engine mounts. I got the trans mount installed loosely to keep everything straight, and then went through and tightened everything down per their instructions. I did have one of the engine mount bolts start to spin, but it's tight and not going anywhere so it should be fine. If I do need to get it off, there is more than enough resistance for an impact to zip it off.
And with that, it's in!!
Supported by it's own mounts for the first time:
