e30318is5-lugm54
    whered you buy the trans pin rebuild stuff?
      My replacement core support also had that stud, and man was that convenient to have for mounting things lol.
      Looking good!
      I hate that one offset hole in the block, M50NV does the same thing when compared to M50.
        snap said:
        horns arent something you normally think of as an upgrade unless you are a subaru guy that wants to have pink horns to match the pink sti emblem, but in my dadcar I often wonder if people even hear me when im trying to roadrage them
        I never thought of it before either, and initially it seems silly, but the number of people who aren't paying attention or just don't care while they drive in the downtown Milwaukee area is ridiculous... I figure it'll at least slightly improve my chances of not having to find more clean body panels!
        It's all available from BMW! I got it everything from Tischer for around $70. Here is a great DIY that also has all the necessary part numbers: https://webspace.ringling.edu/~dplassma/bmw_diy/shift_pins/shift_pins.html
        If anyone needs/wants to do the same thing to their ZF 5-speed, you are welcome to borrow the drifts for setting the bushings/caps, just shoot me a PM.
          I have a ZF laying around and the shift pin kit. Want to throw them in there for me?
            thanks for the info! i'll def. take you up on that if I drop my trans for any reason.
            related to that note, when you stuff your engine/trans in, I'd love to help for the knowledge. the other instances i've installed or removed a 24v from an e30, the whole front of the car was missing.
              Somewhere in the middle of getting that reverse pin snap ring installed I told myself "I'm never f%$#ing doing this again".... that being said it really wasn't horrible and I'm easily persuaded by beer haha
                More things done!
                Installed the clutch slave and related brackets so I could make the hard line that connects the slave to the flex hose
                Also installed a stainless steel pivot pin, retainer spring, and a new clutch fork. Throw-out bearing and pilot bearing will be here this week, along with an FX stage 2 clutch kit with the chromoly lightweight flywheel from Gripforce (Ebay 20% off sale came in clutch...heh). Going to pull all this apart to clean/grease everything, but just wanted to make sure I wasn't missing anything. I also replaced the leaking shift shaft input seal, this job was sooo much easier with the trans outside the car.
                The M54 doesn't have a great place to mount the e30 coolant temp sensor for the cluster, so I shaved off one of the coolant temp sensor locations from the lower radiator hose and will be tapping it to accept the e30 sensor (along with some JB weld for good measure). Because it is plastic, I had to add a grounding wire to the housing of the coolant temp sensor by drilling a hole through one of the edges and soldering a wire into the hole. The other end of the wire is a ring lug that will be grounded to one of the studs holding the vanos assembly to the head. I need to re-solder the connection as it didn't bond to the brass, but it should work well once that's re-done.
                I got the fuel system as far as I can till the engine is installed. I'm using an S54 fuel pressure regulator housing with the 3.5 bar fuel pressure regulator from a 530i. I used an M12x1.5 to 5/16" barb to adapt the FPR housing to the pair of fuel lines at the frame rail in the e30 engine bay:
                The charcoal canister from my car is in great shape so I am going to attempt to retain it to avoid having the car smell like gas and be ever so slightly environmentally friendly. I used the fuel rail hose clip from the M42 to secure the FPR housing in place and orient the outlet towards the engine.
                Access to the brake bias valve isn't great, but I routed everything in a way that I should still be able to get my hand down there and turn the knob with the engine installed.
                  fyi, my tank vent line with filter to the atmosphere doesn't give off any odor. i applaud you for worrying about nature, and all that.
                    Dropped off the oil pan to have the baffle welded in this morning. Once I get that back, it can be bolted in, and the engine will come off the stand for good (hopefully). I have a gripforce stage 2 clutch (sprung hub) and chromoly lightweight flywheel ready to install, and then the transmission can be mated up with the engine and the whole shebang can go in the car!
                    For those of you 24v people, is it easier to install the engine and trans from the top or to remove the subframe and install from underneath?
                      of all the engines i've pulled from e30s, a 24v isnt one of them, despite me owning two. i still have an opinion though, this is the internet, after all.
                      does your hoist have a leveler? the engine will have to go in at a steep angle from the top. a trick I've read is to air out the front tires and jack up the rear of the car to reduce the angle of the dangle.
                        I have a hoist but no leveler, wouldn't be hard to get one though. The other issue I have that I just realized is that the garage door opens over the engine bay so I can't hoist things super high, maybe not the best layout for this... that may force a bottom entry. How steep of an angle are we talking? Like more than 45 degrees?
                          https://youtu.be/Z3ncelZ0PBc?t=1m5s
                          no load leveler, but some helping hands instead. looks like they had to get the hoist about 8' up in the air (hence, pulling the car outside). let me know if you want help!
                            On e36 I just hook the chain on the front lifting point and you get the perfect angle, and you can pull the engine with trans on no problem from the front hook.
                            I have a load leveler you can borrow.
                            you could push the car outside and put the engine in.
                              I remember closing the garage door part way to get the engine hoist high enough when doing mine and brians engines. Food for thought.
                                joe!!! https://www.r3vlimited.com/board/showthread.php?t=423153
                                  Thanks for the tips guys! I'll have to look and see what kind of space I have. Pulling the car into the driveway could block one of the people who lives in the house from getting their car in/out of their parking spot so that may be a problem... I'll have to investigate and take some measurements. I just picked up the welded up oil pan so I can get back on this as soon as I get back!
                                  Ugh... why do these things always have to come up when I just bought something else! That's a pretty decent price, especially since it includes shipping
                                    Ohhh man. Those style 15's😍
                                      Haven't had much time to work on this, but was able to sneak away for an hour today. Got the oil pan back from the welder a week ago, mounted it up with a new gasket for good today:
                                      Then went to test fit the power steering pump:
                                      Damn. The feed line to the pump contacts the oil pan, causing the outer mounting bolt to be misaligned by around 3/4". I haven't heard of anyone having pump mounting issues with the e34 oil pan, so I checked realOEM, and found that BMW has a different part number for the RWD and AWD e46's. You can apparently use both the Luk LF-20 and LF-30 pumps (I have the 30) with this swap, and I would be very surprised if there were actual differences in the pump itself between the different drive types. You can't buy the brackets separately, so I'm thinking the mounting brackets place the pump in a slightly different spot, hence the different part numbers.
                                        Couldn't you just make yourself a new mounting bracket?
                                          Redrill the one hole in the mounting bracket?
