pistonse30
    Where have I heard that name before?
    From what ive researched, if you tap into an existing + from an ABS sensor then you need to amplify the signal like you mentioned the other day. Dialing in the amplification on that link I texted you looks like it requires an oscilloscope and an electrical engineering degree which is why I suggested making a bracket to mount a standalone wheel speed sensor.
      I have the entire abs harness ecu and sensors from my obd1 e36. Let me know if you need any of it.
      Sent from my potato phone.
          Where have I heard that name before? From what ive researched, if you tap into an existing + from an ABS sensor then you need to amplify the signal like you mentioned the other day. Dialing in the amplification on that link I texted you looks like it requires an oscilloscope and an electrical engineering degree which is why I suggested making a bracket to mount a standalone wheel speed sensor.
          he is a BF.C frequent user that has helped answer a few of my questions and knows his stuff.
          I remember he used some signal converter that was cheap and got it to work great. Just facebook him or get him on BF.C. He will answer your question without any head scratching.
            Derek and Snap have been huge helps
              I have the traction control under control in my head after a bunch of texts, a phone call and a little research on my end.
                Intake Air Temp thread reference. Going to order a barbed vacuum fitting.
                  The one on the underside of the manifold?
                  Wiring for traction control looks about right, though I have not used one of the conditioners. What one did you end up using?
                  Edit: Just kidding, went back a page and found it.
                    The one under the manifold.  I'll order this today.  http://www.ebay.com/itm/like/161772492725?ul_noapp=true&chn=ps&lpid=82
                    I went to David Hobbs Honda yesterday.  He didn't put me in a honda but I gave him money and he gave me hondabond.
                      Now I'm confused. You are plugging the stock IAT port, and putting a vacuum line on it? I assume you are going to a GM style IAT sensor mounted on your charge piping?
                        The open element sensor is going to be advantageous for turbotime
                          Ordered two of these.
                          http://www.knifecountryusa.com/store/product/118873.118902/norton-sharpeners-ib6-6-india-alundum-175th-anniversary-edition.html?avad=55963_f9615842
                          I'd be kicking myself if I blew the head gasket again without preparing the block the proper way.
                          This weekend I'll get my oil cooler sorted out, order some other parts and put some work in!
                            Good choice. Nearly everyone In our building has one of those, and I own one as well.
                              The stone block is the farthest thing from the proper way lol.
                              It's just a way to do it that allows you to keep the motor in. Not that it won't work, but unless you managed to warp your block you stand a chance of messing it up when you do it by hand.
                              You only use the stone a couple times, then you switch to sandpaper over the stone.
                              It's pretty easy, but you will have some very tired arms after!
                                It's far better than doing nothing, right? I'm just nervous about that .0015 gap on cylinder #6.
                                What would you do?
                                  I'm conflicted.
                                  .0015 is practically nothing, but I get your concern.
                                  I would give it a pass with 600 grit to see if any high and low spots show themselves and go from there I guess.
                                  I can confirm that the  head gasket that you and I use squishes a lot, so it should have no issue with a .0015 variance
                                    I'm conflicted.
                                    Okay. Maybe I'll do that. Save my arms!!
                                      -Car on jack stands
                                      -Took Echo gas powered 191mph leaf blower and cleared underneath the car after removing oily cardboard
                                      -Move some other boxes around
                                      -Almost started doing the diff swap
                                      -Left garage
                                        DrLeadFoot said:
                                        -Car on jack stands
                                        -Left garage
                                        I was pretty sure this was a KaiserRolls post until I quadruple checked the username
                                          I'm getting my motivation though. Going back to basics, just go to the garage and chip away every day.
