That's the diagram I should have used=) Technically in a multipiece wheel, the lip and barrel would be the "rim". It is really a preference situation now since it has been misused so much.
I'm not saying rim isn't correct now due to industry but it was used incorrectly for so long that it became correct/acceptable.
People still use ain't even though it is not a word. That is similar to the wheel versus rim debate in my mind.
Edit: Also Wikipedia states the same so it is the gospel: https://en.wikipedia.org/wiki/Rim_(wheel)
Ultimate thread Jack. Went from turbos to Andy loving penis
You should always ensure your ANDYLOVESPENIS's are tight prior to spooling your turbo.
HAHA
Back on topic...for now.
Out with the old, in with the new!!
Brand new S54 oil housing on the left, S52 on the right.
Just ordered the 14mm to 12mm Vanos banjo bolt from VAC Motorsports.
That housing takes up so much room!
any reason you didn't use something like the champion oil filter relocation with a thermostat? Not real sure about the benefits of s54 housing, though. I just love the look of a hidden oil filter haha.
Less work, oem reliability and avoiding a lot of a/n fittings.
I definitely thought about getting the vac or Achilles units but $$$..
Vent oil temp gauge install:
Mark your spots to cut
Cut
Small cuts and some sanding of the upper and lower edges and she fits!
Now on to the fun part.
That's all for now, folks!
Yes, I will. I have to figure out how to secure it in there. The spindle that came with it is too big. a bunch of electrical tape?
Hot glue, silicone, electrical tape? haha You guys are
Enlighten us! Haha
If you say Velcro... #overthehill
I would even think a piece of hose (or PVC pipe maybe) that has the same ID as the OD of the gauge. Slip it over the gauge up to the front. It could pinch the vent ribs between the gauge lip and the hose, applying even pressure hold around the entire gauge. Just a thought.
