pistonse30
    Need a head gasket....
      ....but does it bring all the boys to the yard?
        Arent you running an MLS or o-ringed stock gasket currently?
        Im interested to see where the gasket failed or if the head studs lost a little tension and the head lifted
          MLS.
          I've been waiting for this to happen. The last thing that kummrow did that I haven't gotten my hands on to fit the right way.
            So now what?
              Well that sucks.  Another one in the win column for Kummrow!
                Wrip off the head tonight and try to take the cams out without snapping them.
                Take the head to the machine shop and get it inspected. Order appropriate MLS head gasket after the head is machined if it needs it.
                Install.
                  I'll see when I take the head off if the bolts are the same in terms of tightness.
                    Did you retorque the head studs after a few heat cycles on the engine?
                      I didn't.
                        I forget the exact time that should be done, but I think they're supposed to be re torqued around 500 miles.
                          Wasn't aware of that...oops
                            ARP doesn't mention anything about a retorque, its actually in their FAQ's saying that you shouldn't need to. Not that it is a horrible idea, but its a heck of a lot of work on these motors. Standard sockets don't fit between the cam trays and head, and getting the VC off is no fun ;)
                            Sucks that it failed, but luckily its not a hard job!
                              So not coming to Concours Saturday now?
                                I'll be e46in'. Don't get sunburn from that engine light.
                                  I gotta wonder why you wouldn't go with a cut ring gasket or o rings? And do you have any logs? Did you ever get rid of that richness?
                                  I would definitely borrow a nice caliper and measure if those bad boys stretched. I'm kind of excited to see what the pistons look like.
                                    From what I can see there is no need to re-tighten the head bolts on the engine.  Not according to the replacement and torque procedure at least.
                                      There is hardly any room between the 87mm cylinders. Not sure if I can o-ring it
                                        I'm still running rich. It drops into the 10s at 4-6k
                                          http://www.cesmotorsport.com/documents/94.html
                                          They have an 87mm cut ring gasket for ya! Everyone is raving about them on BF.C
                                          But yes, you can O ring it still, but that would take a trip to the machine shop. Cut ring is faster/easier.
