pistonse30
    It's cold out there, son!  :D
    Thanks, Snap!  Maybe next winter I'll upgrade the fuel system and go megasquirt.  I'll be calling you hourly when I cross that bridge.
      I'll wrap this day up with a couple of words:
      From my last dyno run to today I basically got my sparkplugs right, added a full 3in exhaust, fixed a couple vacuum leaks and added CCV.  I thought the vacuum leaks would hinder HP more than it did or maybe the exhaust is way more restrictive now than it was coming straight out of the hood.  In the end I'm in a good spot with only more to gain.  Now who wants to pull out my wastegate for me??
        The face of 442whp <<
          This thing is sweet as gold shoes!
            E85 surge tank setup and megasquirt go go go go!!!!!!!
              It just loaded for me... But in post 443. That second pic of the front of the car. Is too freakin' cool.
                I had the good camera out today!  Thanks!
                  List of things I need.
                  -Fuel pressure regulator adapter for a M50.
                  -PLX Devices power plug for the wideband.
                  -Bigger I.D. vacuum line for my wastegate and the fittings to go with it.
                  The vacuum line should raise the boost up but I don't want to do that until I get my wideband working (again). Then I can dial it in with the FPR.
                  I'm also going to have Kummrow fix my oil leak. Messed my arm up and wrenching probably shouldn't be happening.
                  • RamRod E28R
                    RamRod E28R
                    RamRod E28
                    We got ourselves another earl ladies and gents
                    1988 BMW 528e - Need parts?
                    1996 Mazda Miata (SOLD!!!)
                    1996 BMW 325i (Donor car)
                      Ordered the PLX power cord.  Waiting for I.E. to call me back with a price for the M5X/S5X fuel rail plug and will be ordering that today.
                      Also got this coming http://www.crutchfield.com/p_500HD149BT/Alpine-CDE-HD149BT.html?tp=5684
                      Let the Alpine BLAST!
                        Nice, I like Alpine stuff, my truck has an Alpine CD player from 1995 that still works great.
                          Fuel pressure regulator adapter kit for the S52 has been ordered.
                            Your valve cover is powder coated right?  Is the underside coated as well?  I am getting mine done, and plan on leaving the studs and little screws in and just getting new ones afterwards so that they will keep the coating out of the threads.  Just curious how you did it.
                              I ordered it from Renewed Finishes in Cali. Not sure what he did with bolts. The underside is bare metal.
                                Ok thanks.  I will try to tape off the bottom then.
                                  Hopefully will be getting the car back today.  It should be leak free!!
                                    No car today. I'm getting depressed... :(
                                    • ClassEC
                                      ClassEC
                                      ClassE
                                      Never mind - found it above (I missed why you took the car someplace).
                                      Hopefully it's back soon!
                                        The car is back in my possession!
                                        The filter install is for you, Snap!
                                          :D
                                          hows it running?
