Chapter GMW | E30 LS1 (starting on post #1427)
It just loaded for me... But in post 443. That second pic of the front of the car. Is too freakin' cool.
I had the good camera out today! Thanks!
List of things I need.
-Fuel pressure regulator adapter for a M50.
-PLX Devices power plug for the wideband.
-Bigger I.D. vacuum line for my wastegate and the fittings to go with it.
The vacuum line should raise the boost up but I don't want to do that until I get my wideband working (again). Then I can dial it in with the FPR.
I'm also going to have Kummrow fix my oil leak. Messed my arm up and wrenching probably shouldn't be happening.
We got ourselves another earl ladies and gents
Ordered the PLX power cord. Waiting for I.E. to call me back with a price for the M5X/S5X fuel rail plug and will be ordering that today.
Also got this coming http://www.crutchfield.com/p_500HD149BT/Alpine-CDE-HD149BT.html?tp=5684
Let the Alpine BLAST!
Nice, I like Alpine stuff, my truck has an Alpine CD player from 1995 that still works great.
Fuel pressure regulator adapter kit for the S52 has been ordered.
Your valve cover is powder coated right? Is the underside coated as well? I am getting mine done, and plan on leaving the studs and little screws in and just getting new ones afterwards so that they will keep the coating out of the threads. Just curious how you did it.
I ordered it from Renewed Finishes in Cali. Not sure what he did with bolts. The underside is bare metal.
Hopefully will be getting the car back today. It should be leak free!!
No car today. I'm getting depressed...
The car is back in my possession!
The filter install is for you, Snap!
Great! I haven't really gotten into the rpms yet. Letting the gasket sealant set. The vanos was two teeth off I guess so I'm excited to see how that affect the output.
So jealous - can't wait to see it in person.
I'll give you a ride! My only request is that you're on cop watch like an eagle.
The car is running great! No leaks except for a drop of oil on my cardboard by the power steering pump area. I'll keep an eye on that.
Installed this radio. Bluetooth is working with my Samsung!!! Today was a good day!
Installed new rear shocks. These were shot!
While I was down there I noticed my sway bar bushing slid out of the mount so I reinstalled that. I'll keep an eye on it.
After I was enjoying my new radio I think I blew my brand-new alpine R12. I might need a new amp. Oh the joys of ownership.
Just cause Braun hits a 3 run homer. Doesn't mean you have to crank the stereo!!!
H3gon3
