  4. Shop Life 2.0
Shop Life 2.0
nochristmasjazz
    Looks like the sign has landed on my car this year... Thanks @GunMetalGrey
    8Q-x5EC-uBOFN9UP1mJuk-M5BgYoRBrmb-b30s27
      You made it last year! Id love to see all the new changes in person. Have you found a dyno to get it tuned on or are you going to DIY?
        If I get the car to the picnic, it will be on a safe DIY tune. Once I prove out that everything is working properly, I'm hoping to rent dyno time somewhere and do the tuning myself. I guess it all depends on how comfortable I feel once I start dabbling with the tuning software. Conceptually, I have a good idea of what needs to happen, it just depends whether or not I feel confident executing the plan myself at that point.
          ECU mounted in a legitimate fashion. This is a first for me.
          lTn44D2AwZm7I4OCyeu5hUPS5Sya6uzcoS6y1H3z
          Our neighbor Woody dropped off this Hazard Fraught bead roller a year or two ago and said to try it out. It's been sitting around, untouched, ever since. I'm pretty sure he forgot that he even gave it to us. By mid-day Saturday I'd had enough of dealing with wiring and decided to work on the charge piping for a while to clear my head, so I set it up.
          I feel a little bad complaining about it because it worked and it was free, but this thing is seriously bad. Out of the box, it felt like picking up on someone else's half-finished project. Didn't come with any kind of stand, nor did it really seem to have any provisions for attaching one. I guess you're supposed to clamp it in a vise? Doesn't really work with where our vise is. Aside from the obvious pinch-point on the business end, there are some nice chompy gears waiting for an opportunity to get you on the other end.
          The edges of the female die was sharp enough to cut yourself on, so I had to chuck that up in the mini-lathe and used a file to round off the corners so they wouldn't cut into the pipe while it was being rolled. The irony of using a HF tool to fix another HF tool was not lost on me. It worked though, so that's one thing off my list.
          z4WkHE12FaGApJTLpHFGJemWuAQrBoa9qkZT9a
          stglhy733lo9DPTeGrFKkqlPD0JmndHxc5HHQbI
          S7L1mZieQqFQAIxzCUb29ihwBRqaJYPU7dFcECRz
            I also brought some stuff home to work on. Stayed after work today to re-clock the new turbo. As long as I had it apart, I decided to clean up the turbine casting in a couple spots that I didn't like. The other one that's not pictured is the inlet to the wastegate. It's just a hole drilled perpendicular into the side of the turbo, so I put a radius on the inlet side. Probably not a huge improvement, but it makes me feel better.
            fJbLw2i34fYD5y43aLOmfNObL5DtxchUs0npa21p
            SAbX7UykxBcYEH7LjQ-kgreBozRxCACWEKimb-H
              someone else is watching AvE on youtube. nice BOLTR on the bead roller!
                Creating sanity from unsanity:
                So, for most of the winter, this build has gone as follows:
                Saturday: Show up at the shop, do some work maybe, drink some beer, enjoy life.
                Sunday: Maybe do some work, then go home.
                Monday/Tuesday: stress out about work that needs to be done / order parts.
                Routing various gases and fluids from one place to another is basically plumbers work. Even though there have been hurdles to clear, the work that needs to get done has been pretty straight forward. No alarms, no surprises.
                Then comes wiring the ECU.
                My initial (last minute) plan and execution looked like this:
                Aaaaand, fail. So far, every time I've attacked the wiring on this thing I've made some progress, then later realized that I've made some mistake. This is not sustainable, so I've decide that I need to back the truck up and do some actual planning:
                Drawing this wiring diagram out has proven to be way more cathartic than dealing with a mass of wires draped across the engine bay. I still need to translate this into an actual harness diagram so that I know where the point A and point B of every wire is, but after that the actual execution should be pretty straight-forward...
                Fail to plan, and then do some planning = success maybe.
                  Your google photos aren’t showing up for me 😦
                    Thought I could beat the system....
                    Fixed.
                      This is my nightmare
                        I like your new diagram.
                        The 12v while cranking is usually sent to the unloader relay chassis side.
                          ooo, pretty diagram. youll be rewarded by not having a spaghetti mess in the end and troubleshooting will be systematic instead of guesswork. you can put the time in now, or the time in later, but the time gods must have their fill.
                            I do love the printed labels on the Megasquirt  DIY harness
                            /megasquirtbecausethisisahaltechthread
                              Exactly.
                                Pretty sure e21s don't have an unloader relay, so that's easy.
                                Also considering getting a label printer for doing wire labels.
                                I have wire number labels, but I don't think they'll hold up well enough. I've heard clear shrink tube is a thing and works well for protecting labels...
                                  Wow I need to log in more often. This is sweet!!
                                  • The Full BananaT
                                    The Full BananaT
                                    The Full Banana
                                    Printable heatshrink labels with clear heatshrink over it to protect it worked great on my harness.
                                      Digital version. Needs validation. Any volunteers? 😀
                                        Picked up a dozen tamales and some pastor meat for tacos at Abarrotes El Primo in Sun Prairie before heading up to the shop this morning. May have reached a new high water mark as far as shop cuisine is concerned.
                                          damn that looks good.
