  4. Madison - 1988 E30 325i Convertible - Thread
e30325iconvertible
76 Posts 16 Posters 1.6k Views 1 Watching
    Dont tie it down, the sound of it flopping around in the trunk will hit some surprisingly low frequencies that are gonna get you some sick street cred
    • V
      V
      vbhargava
      Minor update: Replaced the ECU with a 173 unit so that I can chip/tune and upgrade the injectors.
      Odometer stopped working so replaced the OEM gears w/Garagistic gears. Pretty easy fix that doesnt require removing the steering wheel but blew out a bulb in the process.
        I would love to purchase a California/Arizona car in the future and either ship it to drive it back. Looks like a really clean example. Early model verts have a great look.
        • V
          V
          vbhargava
          Finally got rid of the white w/M stitching shifter and parking brake boots. Picked up a CATuned set and it fit great. If anyone wants the old set I'm happy to give them away.
          Now its time to upgrade the shifter knob. What's your favorite for the E30?
            zhp knob > all. oem quality, good price, heavy feel.
            • V
              V
              vbhargava
              @straight6pwr Is there a ZHP shift knob w/o the silver ring at the bottom?
                no, but its super easy to spray paint to black. or vinyl wrap it.
                  I think I'm going to have to do this, I really dislike the silver ring. I'll take the boots if no one else needs them, mine are pretty nasty.
                    I have a leather shift boot with the m stripes if you want it.
                    • V
                      V
                      vbhargava
                      My bad I missed this. Still interested in the boots?
                        It’ll probably be early June until I’m back and can get them, so if you don’t want to wait that long you can toss em.
                        • V
                          V
                          vbhargava
                          Decided to add a Red 46 skid plate to make sure I dont kill the oil pan on back roads.
                          Pros: works w/the gargastic x brace.
                          Cons: not bolt on
                          • V
                            V
                            vbhargava
                            ProjectCoCo got some serious love this weekend.
                            1. New passenger fuel sender unit
                            2. New drivers fuel sensor o-ring
                            3. Garagistic rear shock mount reinforcement
                            4. M-tech 1 steering wheel with new M color band
                            5. New headlight knob
                            6. New glovebox lever/handle
                            7. New windshield washer reservoir and pump
                            8. New cowl grates
                              Nice subtle improvements. Those minor details count
                                Everything looks great! Especially the air vents.
                                  Nice! Its all in the deah - tails.
                                  • V
                                    V
                                    vbhargava
                                    Needed a jump start but Coco started right up for the first time since November.  Had a few hours to make some small changes:
                                    • coco mats - black and grey
                                    • collector license plates (need to license plate delete the front)
                                    • new bulb in the rear bumper
                                    • realigned the m-tech 1 steering wheel 1 notch.
                                    • injector cleaner
                                    Summer plans
                                    • raise coilovers 1 inch
                                    • euro grill and chrome kidneys
                                    • replace convertible top latch
                                    • license plate delete up front
                                    • replace coolant reservoir
                                    • maybe:
                                      • 19lbs injectors and Mark D chip
                                      • feupholster seats
                                      • find a replacement front drivers fender
                                      It’s been a while, glad to see progress. What tune are you going with?
                                      • V
                                        V
                                        vbhargava
                                        @B C
                                        I am deciding between a 91 and 93 octane Mark D chip- http://www3.sympatico.ca/mdsylva/products.htm. Any thoughts?
                                        To be honest I'm having a hard time finding a step by step guide for 19lb injectors and understanding the differences in the various 19lb injectors iv found:
                                        • https://www.ebay.com/itm/BMW-E30-E34-E36-M20-M30-M50-19lb-injector-upgrade-Genuine-Bosch-/292975028671
                                        • https://www.ebay.com/itm/BMW-E30-E34-E36-M20-M30-M50-19lb-injector-upgrade-Genuine-Bosch-Gray/293400060812?_trkparms=aid%3D1110002%26algo%3DSPLICE.SOI%26ao%3D1%26asc%3D20200116171858%26meid%3Dd1ac16fed34648e68c7afaf7c51828d8%26pid%3D100008%26rk%3D1%26rkt%3D12%26sd%3D292975028671%26itm%3D293400060812%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DPromotedSellersOtherItemsV2%26brand%3DBosch&_trksid=p2047675.c100008.m2219
                                        • http://maksinjection.com/?product=bosch-0280-155-746-19-injectors-set-of-6
                                        Do the installation of the injectors require anything other then swapping them out?
                                          vbhargava said:
                                          @B C
                                          I would personally opt for the 93 octane tune and this set here
                                          At most you may need to dremel new injector retainer slots in the upper portion of the body. I only had to do this once on as set of 33# injectors which had the clip location slightly different than stock. Many sets I have used did not need any modification.
                                          Not required but good practice would be to do a smoke test to check for any intake leaks and make sure your oxygen sensor is healthy.
