  4. Shop Life 2.0
Shop Life 2.0
nochristmasjazz
    This is what I read lol.
    I AM CONFUSED... and I think I did it to myself.
      I have no experience messing with MS but I know a lot of people know how to use it because its really simple. I have used Haltech and it is fairly easy too,  the database for diagrams online is extremely helpful.
      Thanks for the feedback.
      Another one I've come across is the ECUMaster EMU Black. There's a lot of stuff integrated into it (wideband controller, knock detection, thermocouple inputs), the software looks really nice, and it's like half the price of most of the other solutions I've looked at. Have to wonder where they're cutting corners to be able to offer it that cheap though...
         I bought a ECUMaster EMU Black for my 1JZ E30. I have yet to install it though. I am waiting to thin the herd before shift my focus back to that car. 😄
          Well, hello there.
          Not much do report. Did some moch-ups, tore down the old engine, and eye'd up the driveline. I want to take a 2nd look at it, but it looks like everything is pretty straight right now, so I may not be able to lift the engine up like I wanted to.
          I also didn't really want to do a top-mount, but it looks like the only place that makes sense in terms of packaging. Starting to have feelings of inadequacy related to the size of my turbo...
            passenger footwell.
              Awesome!! Are you using an off-the-shelf manifold or custom?
                I'm assuming it will have to be custom, but I need to look into what others have done. I've heard you can take an M5x manifold and lop two cylinders off, but I'd still have to change the flange to run the Mitsubishi turbo.
                  Oh ok, I was thinking you had the turbo on a manifold already! I think jakeb/classic daily makes an m42 e21 turbo manifold with his turbo kits, not sure if he still sells them (or sells them separately) https://www.r3vlimited.com/board/showthread.php?t=259174
                    This could be an option, but I like to fab stuff, so I'll probably make my own.  Also gives me the flexibility to mount the turbo where I want it (currently undecided).
                      Craptastic header mock-up v0.2 complete
                      The PVC didn't work out as well as I thought it would. I couldn't get it to bend tight enough without kinking, or get a consistent radius bends. Regardless, I was able to figure out how to route things. There's not a lot of room on that side of the engine, but I was at least able to verify that I will be able to build something that will fit in the chassis.
                      Still need to get flanges made, but I'm hoping to be able to start round 1 of header fab next weekend.
                        filling the PVC with sand, capping the ends and using a little heat while bending helps keep the PVC from kinking. But either way, looking good!
                          That's how they make jacked race headers for boats. They have two tubes, one inside the other, and fill the void with sand before bending. The only difference here is that its PVC and not stainless.
                          Related image
                            Started out the weekend by trying to impulse-buy a band saw, but couldn't find anything locally that didn't look like more trouble than it would be worth. So, we're back to doing things the Mike way (aka the hardest way possible).
                            I picked up a bunch of 2.5" radius U-bends, so first order of business was to come up with a way to cut them straight and square so that they mate together nicely. Not having gaps where the tubes butt together should make it a lot easier to weld. I decided a jig that the tube could sit in with a slot to hold the sawsall blade straight would probably work.
                            FLIJ0sRc43pbwT1uTc1OeNWesvX9wQYF6toPT80
                            XwEg262L9PAd5i3uNRNWvPsDdmfSaC7BbxDZuDjD
                            I've only tried it once so far, but it seems to work really well. Better than expected actually.
                            The next hurdle was to figure out how to oval the end of the tubes so that they can mate up nicely to the exhaust ports on the head. I had researched this one a while back, and the best solution I found was to create a die that's the same shape as the port, and then hammer the tube down onto the die.
                            pvXgqHlnr3t4ESEHeJjdidGvigHC05s8I0odyIcB
                            SFv4MEEUlAb8pkexEh1a8LWAYRI1uEuZ4DWmCjT-
                            FPEerr1ZjLmjr7FvocdXCRxnPmbY1OminaMOUH5R
                            Decent!
                            The last area that I'm concerned about is the collector. The tubes need two long tapered cuts at 90 degrees to each other. I had basically given up on figuring out how to do it with the tools I have and was going buy a stationary belt/disc sander to mount a jig to, but at the last minute I came up with a different plan.
                            C0mMqQdnMC-4QD5T7aJBGDXbnvWT7xRJA383ov9
                            BDr25h4w7kkDW7U8m0Xs84XusphMPBbyDXJ7xQQn
                            Ben is very concerned for my safety, and I'm willing to admit that this probably isn't one of my best ideas. I gave it a go with some PVC, and it seems to work well enough. The cuts aren't super straight, and will need some hand-finishing. I was also eye-balling the 90 degree turn for the second cut, so it didn't turn out perfect, but if I can figure out a better way to do that it should be good enough to get by.
                            XUOGvianw7aCJVlDGnsrnWhDK11Fsar4FUWlhZbp
                            xU9aD1YzjpVPMdJjGEDiLqehIaym0DVDxmz4DReG
                            I still haven't gotten flanges made, so I couldn't really start building anything yet, but I'd say it's going pretty well so far.
                              I envy your craftsmanship but you're also crazy!
                                Very impressive ingenuity as usual!
                                Perhaps these may be helpful?
                                its not the way its usually merged for a turbine flange but it may prevent a headache or two
                                https://caautoparts.com/products/2-25-4-4-1-exhaust-merge-collector-excol-225-4-ss?variant=40443660105&gclid=EAIaIQobChMI8bGJ4IPg3gIVhbjACh1EFQBcEAQYCSABEgJpxPD_BwE
                                  Might I suggest a band-saw? No really, You work a few blocks from me and I should have everything you need here besides your car. Mark what you need cut and shoot me a text and come cut it. ;D
                                    I enjoy the DIY-style of your builds.
                                    I also think you would benefit from a band saw.
                                      band saw for sure. I ended up getting the portaband from Harbor freight. Slapped a Milwaukee blade on it and welded up a stand for it as well. Works wonders for these kinds of things.
                                        If I fail at DIYing one, I could do something like that, but I don't accept defeat easily...
                                        There isn't really a need to transition to a round tube, because the turbo inlet is kind of square-ish anyway. I planned on cutting the turbo flange to the shape of the pipes to make life easier.
                                          This could be an option.
                                          The problem isn't as much the tool that's being used to do the cutting as it is holding the tube in the proper position while it's being cut. Even if I had a nice bandsaw, I would still need a "sled" to hold the tube at the correct angle, and a way to rotate it exactly 90 degrees before making the 2nd cut.
