Non-BMW Stuff on a BMW Forum
    Switching gears here:
    To those with e30s who drive theirs pretty frequently with the occasional spirited driving session and maybe some autocross: what engine and transmission mounts do you have?
    I currently have the condor solid engine mounts and poly 80a transmission mounts and the vibrations/noise they transmit is too much for what I want the car to be - a comfortable spirited daily driver for the summer with an occasional autocross. I would like to go back to stock engine & transmission mounts but hoping to get some input on that.
      New DME and Fuel Pump relays are never a bad idea. I kept spares with me at all times as a cheap easy thing to keep me going if i ever found myself dead on the roadside. They have been known to cause similar issues. The other item is the injection harness corrosion and crank sensor alignment. I had powdercoated my bracket along with all my other engine parts and that thin film of plastic was enough to cause the car to cut out at 4500rpm. new uncoated bracket fixed it
        As for transmission mounts. use E21 mounts with reinforcement cups. Anything stiffer than original rubber becomes a NVH issue. Condor UHMW/poly Engine mounts are just fine in the NVH department.
        Now please excuse me while I go back into hibernation
          That's right. The relays were another thing I read to replace. I will replace those as well. I had also powdercoated my CPS bracket, it might have made the issue worse, but I believe the bracket was still a little messed up before powder coating. I am ordering a new bracket.
          The e21 transmission mounts and e24 engine mounts appear to be the go-to HD stock engine mount substitute. Probably best to go that route.
          Goodnight.
            When the 1990 was still streetable I had the e21 transmission mounts (w/o cups) and the BW engine mounts (probably same as the e24 in terms of hardness)
            https://www.bimmerworld.com/Engine/Engine-Mounts/Heavy-Duty-E30-325-Engine-Mount-Set_2.html
            If you go with the e21/e24 combo watch for Garagistic's Black Friday sale coming up later this month, here's the current listing but they usually have some good BF deals. If you sign up with them you get early notification of deals
            https://store.garagistic.com/E30-hd-mounts-23711175424-11811132322
              I think you're on the wrong forum for this question.....
                Garagistic does offer a ton of sales, so that's a good idea. I saw their kit and was going to get that, but found the same mounts (searching part numbers) on RM European for $8ea.
                  lol. I have noticed that many of the cars here are on jack stands.
                  I should rephrase that question:
                  To those who have driven their car at some point while in their ownership...
                    Still wrong forum.
                      Still wrong forum.
                      To those who have installed engine mounts: did the poly engine mounts or rubber engine mounts feel better in your hands?
                        Just my two cents, but for a street car I’d go for the HD OEM stuff if I were you. Usually not very expensive, it should last a long time, it’ll make the car more pleasant to drive, and you really don’t have to worry about fitment or quality like with some aftermarket stuff. Obviously, if it’s gonna see track time that doesn’t apply and I’m of absolutely no help, but for what it’s worth I’ve been nothing but pleased with every OEM bushing I’ve put onto my car (except for rear shock mounts, the stockers suck wiener). Other people will be better sources for info for autox stuff, but this is my recommendation for a car capable of spirited driving.
                          I ordered the e21 and e24 mounts. I think they'll do the job. I would like to get into some autocross next year, but I'm guessing it will be fine.
                          I intend to almost daily this next summer, so I would like it to be as comfortable and quiet as it can be while still being great for a spirited cruise.
                            Good night sweet prince. Put it up on jack stands for the winter to address everything. Also trying to figure out the culprit for the p0171/4 code on the e46. Not the disa valve!
                            Every time I look at these pictures I find the Volvo flag ironic.
                              So my front bumper was always a little out of alignment. The PS stuck out further and there was a gap. Can see it here kind of.
                              Took it off and found these with the mounts. Looks like someone was a little too aggressive when towing the car at some point. 20181104145656.jpg
                              After beating on it with a sledge hammer it's much improved, but still a little ways to go.
                                Well, car has been parked for a couple weeks now and last night I noticed a small wet spot on the ground towards the back of the engine. And of course there is oil coming out of the weep hole on the bottom engine cover piece. 😒
                                I guess I'll add RMS to the list for the winter. I had replaced it while the engine was out, but I'm going to use the OEM seal this time. It's annoying, because I would check it almost every time after I drove it and never noticed any leaks back there.
                                  Lame. Cars tend to leak more if they sit for a long period of time vs. driving a lot. Sadly I know this is a fact.
                                    Started tearing into it tonight by removing the exhaust. Back half is toast.
                                    And then snapped one of the studs on the rear manifold. Soooo, if anyone has a rear exhaust manifold for an m20b25, let me know!!!!!
                                      Fun fun. Rusty exhaust sucks.
                                        Im glad that this car is being revived. There's not many cars that can give you the kind of driving experience that an E30 can.
                                          The little bit I drove it this year was wonderful. Looking forward to getting a little more power/driveability out of it. Going to do a lightened flywheel while the transmission is out and then a chip.
                                          Does anyone here have a lightened flywheel, and how low did you go?
