813 Posts 31 Posters 0 Views 1 Watching
    Thanks. They shouldn't be needed for this stuff, so you're good. No rush
      Driver side wheel arch cut, welded and finished. On to mounting the rear flares...
        Man im stoked for this.
          Rotted out trunk seal lip cut out, fabricated and welded in.
            Started fitting the rear flares and figuring out where I need to cut/section them to fit better.
              Group 5 roof spoiler installed
                No dust dix thank goodness
                    Was finally able to do more work on this. Got the passenger side rear flare cut, sectioned and fiberglassed back together. Used it to get the measurements and did the same on drivers side. Will just need some finishing with bondoglass and body filler before 2k epoxy primer and vinyl wrap.
                      Getting there. So will we see this road worthy this season?
                        Most likely not. Life's been getting in the way mostly
                          Well life has finally slowed down, just in time for winter ... uugh. Wish it was spring, but better late than never. Finishing up sanding and priming the rear flares so they can get vinyl wrapped. Then the rest of the car can be wrapped as well.
                            Waiting on the 2K epoxy primer to come in mail.
                              All primed and ready for wrap next weekend hopefully.
                                Saw this article today, guess who came to mind...
                                http://www.speedhunters.com/2018/12/jim-busby-racing-bmw-320-turbo/
                                  Rear flares fitted. Time to figure out how to finish this wrap in the cold weather. 🤔
                                      Is the garage insulated at all?
                                        No insulation unfortunately.
                                          Its a very nice.
                                          Image result for borat gif
