  4. Joined the Club Today
425 Posts 20 Posters 0 Views 1 Watching
    you need the shifter bushing specific to the shift carrier. it should be e36 everything for the shifter setup with the ZF trans.
    there is a poly(or delrin) shift bushing out there which is a good 'fix it once and never again' upgrade. i wouldn't recommend garagistic, but it was the first i found on a quick search.
    https://store.garagistic.com/bmw-performance-parts/bmw-3-series-parts/bmw-E36-parts/e46-oval-shifter-bushings
      I have the gripforce stuff in my e30. Toss the TOB and pilot bearing for something of OEM variety (unless they now come with good stuff)
        While you're refreshing the shifter I have a Garagistic rear carrier bushing that I already installed in a stock sleeve. I won't be using it and will sent it to you for $20
        https://store.garagistic.com/Rear-Poly-Carrier-Shifter-Bushing-e46-e36-e31-e92-e39-25111222015
        I also have a Ruff Racing adjustable shifter if you'd want to upgrade. I can give you details if you'd be interested. I started selling them for some spare change on the side. They're $175 shipped👍
          Think I might grab @Earl's
          Not sure if there is a good way to verify that or not, but will likely just buy some OEM type stuff.
          Do you have a stage 2? Would this be a good option for a non daily, mostly street car?
          Or should I go for the Stage 1?
          Probably interested in that bushing and sleeve. I will PM you.
            So I actually misspoke. I added the correct shifter bushing to the cart now. However, I was originally referring to the bushing that goes in number 4 in this pic
            Is this the correct item to replace that?
            I appreciate everyones help.
              someone said:
              This can only be used if you also run delrin transmission bushings. The transmission and shifter having different allowable movements will cause linkages to brake, difficulty shifting and other issues. We also offer a hard poly version of this bushing for people who run rubber/poly transmission bushings. Those can be found here.
              leave it up to garagistic to be about as intelligent as the average craigslist-er.
              youve got the right part. the one earl is offering is not for an e30.
                Thank you, I will probably go with their poly version to pair with the trans and motor mounts.
                  I had forgot this was for his e30=(
                    The garagistic part looks like a 'meh' solution to replacing that bushing, but I'm biased and have had nothing but trouble with their products. Turner makes an excellent piece that includes a stainless version of the bracket. It's quite a bit more expensive but this is what I would probably buy if I was doing that job, plus it's the same cost as just buying the OEM one:
                    https://www.ecstuning.com/b-turner-motorsport-parts/shifter-bushing-assembly/021011tms01a/?gclid=EAIaIQobChMIydis9KLi2wIVWbnACh2A4Ay-EAQYAiABEgIgnPD_BwE
                    • AsparagusMikeA
                      AsparagusMikeA
                      AsparagusMike
                      This ^
                      FWIW, I used the Turner bushing for my linkage and its a very nice part, stiffened everything up quite a bit more vs. Oem and its gonna last quite a bit longer. The price is a little high in terms of what ur getting so I would talk to patsbimmer about pricing, he got me a much better deal on it.
                        AsparagusMike said:
                        This ^
                        Just ordered it through @patsbimmer1
                        I also purchased a stage 1 clutch kit through grip force. Bought a lot of seals, tie rods, and other things that I wanted to replace.
                        There should be a good amount replaced on the car by the time it gets going.
                          @SteelBlue i went with stage 2
                            Anyone break a trans bolt head before? Still a good amount of the head left on the bolt, however, all of the hex portion is gone so theres really no way to get a socket on. I've heard using one of those reverse threaded/stripped bolt doodads might do the trick. Just wondering if anyone else has had this issue before. The bolt in question is the large one at about 11 o'clock if you were looking at the trans from the rear. It has the exposed threads at the backside which makes me think I could maybe cut the head of the bolt off and then thread two nuts on the exposed threading and loosen it that way? Don't want to make a hasty decision.
                            First big mechanical issue in this process, many more to come I presume.
                              No but I'd PB blast and heat the rest of them! That sucks
                                Rest of them broke loose fine. This one is the straggler holding it on. Talking with @MPW3RLee, might cut the head off to pull the trans off and then work the rest of the bolt that remains with some heat and vice grip. Or do some other shenanigans to get it out.
                                Could be worse, trans could be still in the car and could have broken it.
                                • ChrisOC
                                  ChrisOC
                                  ChrisO
                                  How far does that bolt stick out past the block? Maybe you could get two thin nuts locked together on the part of the bolt sticking out and break it free that way with some heat
                                    A good amount. That was my thought for getting it out.
                                      If you have access to a welder, you can weld a bolt to the head like this:
                                      Then you can get a proper socket on it and use an impact to get it out. The heat from the welder can help break it loose too
                                        I would just cut it off and there will be plenty of the remaining bolt exposed after the transmission is off to deal with removing it.  You already need a new bolt anyway.
                                          +2 to cutting it off
