    That ooze pic is pretty cool!
    Do you have a part number for that fan switch? im going to get a lower temp one ( @jc43089 you were right about this)
    I hope my heater valve doesnt give up on me anytime soon. I hate removing the hvac controls and working back there.
      i got my fan switch on the 'bay (the ad suggests it doesn't fit late model e30 radiators, but it does.): https://www.ebay.com/itm/BMW-e12-e21-e23-e28-e30-Auxiliary-Fan-Switch-82-FAE-temp-sender-engine-cooling/232727780291?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
      the heater valve is actually really easy, except for the access to the hoses in the engine bay due to the 24v manifold. the under dash stuff takes 15 min. you should hope it doesnt give up because a new one is $250 🙄
      mini write up: engine bay: disconnect the two hoses going to the heater core. interior: ebrake console off, center console off, kick panel off, pop off the hvac accordion vent, one screw for an hvac duct and you have access to the valve. for the valve, take out the two torx screws holding the heater core and slide it out just a little to give access to the (3) 8mm screws holding the valve to the core. one torx screw holding a bracket near the back of the valve's pipes and voila, its out.
        more progress.
        pulled the radiator to get the water pump out. old w/plastic impeller (that likes to explode) and new with metal impeller.
        decided i should finally permanently mount the elec. fan, which was only held by those plastic zip tie things. it was always on the edge of falling off the car.
        found a small crank case filter at o'reillys on capitol drive. there was almost a fight in the store, fun times. anyways, i reused a length of hose that had a nice 90deg bend it it.
        mounted facing down and tucked in this frame pocket so water can't find its way into the system.
        i also got a quick layer of paint on the flaking/rusting brake booster, cleaned up the engine bay a little more and pulled the brake reservoir in prep for the new one.
          remote brake fluid reservoir installed. this is a 2002 res.
          blower motor resistor installed.
          these are just for future reference, since I had them off the car. (upper/lower rad hose part numbers for an e30 24v swap.)
          thermostat/alum housing installed. people seem leery about the sealing at the gasket/housing casting, so for extra protection i threw in some rtv.
          I needed to get my dipstick tube to seal where it enters the oil pan. PO had it ziptied to the alternator and no rubber seal at all. I added the rubber seal last year, which didnt help - it just leaked then blew out pretty quickly.  the new bracket should do the trick. test mockup:
          quick coat of paint
          voila.
          a little extra protection above the seal:
            Did you make that bracket? I still need to make one for mine.
              The o-ring is supposed top go below the ridge.  They are a pain to install.  Oil the o-ring and put it on the dipstick and use a rubber mallet to pop it into the oil pan hole.
                Is this for the fuel tank vent line/purge valve line?
                  yup. just some steel that bent into shape.
                  it is, the dipstick is upside down in that photo.
                  correct. the PO had plugged it, resulting in pressure in the tank only escaping when I took off the gas cap.
                    It is, the dipstick is upside down in that photo.
                    Don't mind this dipstick then.
                      engine is 95% done. just have to extend the brake fluid sensor wiring for the new location and clean a few more areas.
                      manual valve to replace the throttle body thermostat. just a 1/2 brass ball valve from the plumbing aisle.
                      new booster check valve and hose
                      wrapped the engine harness and removed the covers. i hate plastic covers. i'd rather see the guts. new c101 bracket (hard to see here)
                      well hello, ms. lady.
                      teaser pic.
                        Why the ball valve?
                          don't want to completely bypass the coolant for the throttle.
                            I have bypassed the throttle body heater for a long time on my daily e36, no problems so far.  An oil drain plug is the right size to plug the hole in the head.  M12x1.5.
                              The valve cover looks so good!
                                good to know. if it gives me leaks in the future, ill probably ditch it entirely.
                                thanks dude!
                                  front rotors, pads, and brake lines on!
                                  the fasteners on this car are so so un-rusty that the rotor set screw came off with an allen key! i feel spoiled.
                                    Thats a great feeling. I think all of us have some sort of memory of stripping, drilling, or breaking one.
                                    Thanks for the good word on R3V today as well.
                                    Are you planning on bedding the brakes in? To be honest I have never felt certain that ive done a bedding process correctly and I find im better off just driving the thing normally.
                                      i've had to drill at least 1 of the 4 every time i've done this job.
                                      no prob.
                                      yeah i usually do a truncated version of what they suggest. there's no where in the city to do all those 50-0-50-0 stops, so i just do a couple, then drive normal. my brain tells me it doesnt matter, i don't believe auto repair shops do that procedure before handing cars with new pads back to customers.
                                        I did it a few times at Concours but just 0-35ish in the back parking lot a few times but yeah I’m sure it’s not done most of the time. If anything just on the performance brakes.
                                          The bedding in process i've always done has been whatever speed I can get to then slowing down 10 - 20 mph then speeding back up and repeat.  I don't know that I've ever seen a bedding process that tells you to take it to zero or a stop.  The thought process is you keep moving to keep air moving over the new brakes then do a brief cool down with no or light braking before coming to a full stop.  This of course is only if it's possible to not stop.
                                          Also, for the set screws, once I started using an impact driver to remove them I haven't had to drill a single one out.  I've probably done hundreds with an impact driver with zero issues.  It's worth the $20 investment!
