  3. Services Offered/Wanted
  4. E36/E46 rear subframe mount fix.
aokshop
3 Posts 2 Posters 43 Views 1 Watching
  • W
    W
    WildBill
    Now that I have done this fix to a couple of my friends cars I feel confident in doing it to others, every E36/E46 has this problem and I believe it should be taken care of before it makes it a real pain to fix or makes your car unsafe to drive.
    With that being said, who needs to have it done?  I figure i can get this job done in about 15 hours (depending how bad the mounts are), I do work a full time job still so if my schedule is some what limited but I'm very easy to work with. Ex. If i got your car on Monday I could have it done by Friday.  If I got your car Friday I could have it done on Sunday.
    There will be a few other jobs i can do while every thing is already apart if you choose to want them done (Not included into the 15 hours), if you want new sub frame bushings put in I can get that done for you, if you want your fuel tank drained/wiped out i can do that too. Once I have the chassis plates welded everything will be painted and the inside of the chassis will get sprayed with a wax coating to prevent it from rusting from the inside out.
    If you're interested in Pricing and setting something up with me shoot me a message on here or you can send me a text message at (920)-267-1364
    Thanks for looking WildBill
      Damn. Where are you located? I feel like I should get this done sooner than later.
      • W
        W
        WildBill
        Eden Wisconsin, its just a few minutes south of Fond Du Lac
