<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[E36/E46 rear subframe mount fix.]]></title><description><![CDATA[<p dir="auto">Now that I have done this fix to a couple of my friends cars I feel confident in doing it to others, every E36/E46 has this problem and I believe it should be taken care of before it makes it a real pain to fix or makes your car unsafe to drive.</p>
<p dir="auto">With that being said, who needs to have it done?  I figure i can get this job done in about 15 hours (depending how bad the mounts are), I do work a full time job still so if my schedule is some what limited but I'm very easy to work with. Ex. If i got your car on Monday I could have it done by Friday.  If I got your car Friday I could have it done on Sunday.</p>
<p dir="auto">There will be a few other jobs i can do while every thing is already apart if you choose to want them done (Not included into the 15 hours), if you want new sub frame bushings put in I can get that done for you, if you want your fuel tank drained/wiped out i can do that too. Once I have the chassis plates welded everything will be painted and the inside of the chassis will get sprayed with a wax coating to prevent it from rusting from the inside out.  </p>
<p dir="auto">If you're interested in Pricing and setting something up with me shoot me a message on here or you can send me a text message at (920)-267-1364 </p>
<p dir="auto">Thanks for looking WildBill</p>
]]></description><link>https://wibimmers.com/topic/5218/e36-e46-rear-subframe-mount-fix.</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:03:44 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5218.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Mar 2018 23:14:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to E36/E46 rear subframe mount fix. on Tue, 20 Mar 2018 00:54:53 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/89585">Rekpoint said:</a></strong></p>
<p dir="auto">Damn. Where are you located? I feel like I should get this done sooner than later. </p>
<p dir="auto">Eden Wisconsin, its just a few minutes south of Fond Du Lac</p>
]]></description><link>https://wibimmers.com/post/89587</link><guid isPermaLink="true">https://wibimmers.com/post/89587</guid><dc:creator><![CDATA[WildBill]]></dc:creator><pubDate>Tue, 20 Mar 2018 00:54:53 GMT</pubDate></item><item><title><![CDATA[Reply to E36/E46 rear subframe mount fix. on Tue, 20 Mar 2018 00:10:22 GMT]]></title><description><![CDATA[<p dir="auto">Damn. Where are you located? I feel like I should get this done sooner than later.</p>
]]></description><link>https://wibimmers.com/post/89585</link><guid isPermaLink="true">https://wibimmers.com/post/89585</guid><dc:creator><![CDATA[Rekpoint]]></dc:creator><pubDate>Tue, 20 Mar 2018 00:10:22 GMT</pubDate></item></channel></rss>
