e30318is5-lugm54
    Got some things done this week. I swapped the oil pump inner rotor over to the Achilles harneded oil pump shaft, just waiting on a new pressure relief spring and o-ring and I can get the oil pump buttoned up.
    Ebay had a sale so I picked up some VDO vision gauges to keep a closer eye on the new engine. Oil temp, oil pressure, and water temp gauges. I've had a console mounting plate sitting around for a while so I did a quick mock-up, should look fairly factory! I may color the cluster needles orange to make everything match, but that'll be a project for some other time.
    Biggest progress is the m42 is now sitting on the floor of my garage. So much room for activities!
      What else needs to be done on the engine/trans to be ready to install it?  What trans are you using anyhow?
      Keep up the great work! Perhaps you will find more deer blood at this level of disassembly
        I have definitely found some hair, there was A LOT so I'll probably keep finding it forever... hoping to keep the fluids at a minimum haha. Trans is a ZF 5-speed.
        Things I can think of remaining on the engine before I install it:
        - Rear main seal
        - Reassemble and prime oil pump
        - Acquire/Install oil pan baffle (debating this one still)
        - Reinstall oil pan
        - Reinstall P/S pump and serpentine belt
        - Modify oil filter housing (just filing down a rib) and install oil distribution block for pressure/temp gauge senders
        - Clean and paint harmonic balancer, its a little crusty
        - Modify driver's side engine mount arm so I can get the 4th bolt in (or get a later arm with the slotted hole that works)
        - Install main/secondary engine harness (Remove auto-trans wiring from secondary harness)
        - Clean up starter
        - Clean trans (it's filthy) and replace shift shaft seal/selector rod joint
        - Replace shift detent pins
        - Resurface flywheel and pressure plate
        - Probably a million other things
        Probably going to have to re-adjust my picnic goal as I'll be out of town for at least 2 weekends between now and then, but I'd rather do that than cut corners to get it done. It'll be on the road this summer for sure!
          I know the feeling with still finding deer hairs haha
          Super stoked on the progress you're making with this though=)
            My thoughts exactly. I hate rushing things and having to revisit them later. Do it right the first time I always say.
              Agreed. I did a bit of rushing on some things last winter since I was hell bent on making it there, but now I'd like to take the time to fix those things and do it all right. Like last year I wired the electronic fan to be on with the ignition all the time as a quick 'get it done', which was annoying all summer, so now I'm going to re-wire it to a temp switch with a manual override like I should've in the first place.
                interested in seeing how your manual override works. My plan is just to not overheat.
                  I was just planning to do a switch in the cabin in the event I want it on (like for cooling down the engine bay before working on it, waiting in an auto-x grid, etc). I have the fan running on a relay, and basically you have two switches (temp and manual toggle/latching) connected to ground in parallel that can close the relay independently of each other.
                    I just have the 2 temp fan switch. I have individual weatherpack connectors on the 91C and the 99C wires of the switch so I can experiment with both. Ideally I should just put in a manual override switch but I will save that project for another day (after I overheat).
                    Which fan will you be using? I am using the Spal 16" 30101517 with it wired on the high speed fan circuit
                      Last summer I had the deep profile/curved blade 16" Spal puller (30102049) combined with a shroud and it moved a huge amount of air. I was hoping there would be some way I could fit it and not have to buy a different fan... there is no way that's going to happen so I'll likely move to a 16" pusher (the same one as you)
                        All manual all the time for me. It’s easy to get in the habit of flipping it on and off if you’re as paranoid as I am about the temp gauge
                        I also drive with the heat blasting most of the summer with the sunroof cracked open
                        Eat your heart out slick top circle jerkers
                          God I hated doing that on hot days when I didn't have a fan or a big enough radiator installed. Nothing better than being stuck in a hot car, on a hot day, with the heat full fucking blast.
                            Just remove your pants. No one will notice, and its a great way to reduce body heat.
                                swampass
                                  Started making progress on the electrical/ECU side of things. I put together a bench flash harness so that I can start messing around with MS43:
                                  I may have to make some changes/adjustments as there is a lot of conflicting information surrounding this topic, but this configuration seems to work for most people.
                                  Basically, it consists of a 12v power supply, a female OBD2 pigtail, DME connectors 1 and 4 from the e46 engine harness that came off my motor, and a ground wire so I can get it to start in bootmode. I'll be using Galletto/JMGarageFlasher to connect to the DME and read/write partial and full flashes, and TunerPro to modify things like the redline, thermostat temps, play with fueling/cam timing, etc.. I didn't have a T15 torx screwdriver at home last night to remove the motherboard so I'm hoping to connect it up and give it a shot tonight.
                                  Side note, I came across a good deal on a set of genuine BBS gold/blue center caps to replace the roundel center caps on my wheels! They have a really nice metallic blue background that looks almost black in low light and an awesome bright blue color in the sun.
                                    Those centercaps are killer!
                                      ^This
                                      They are retro and beautiful!
                                        those centercaps look fantastic.
                                        roundels for sell?
                                        #imhereforthescraps
                                          roundels for sell?
                                          #imhereforthescraps
                                          Probably! I was going to hang onto them in case I wanted to switch in-between the two, but once I popped the new ones in I doubt I'll ever do that haha.
