  4. BMW Sienna 2.5i build
    The MC will be inside facing back, I ordered a -4AN bulkhead to get through the firewall and an adapter for the MC inlet to -AN so I can put the reservoir in the engine bay.  It would be a pain to check/fill under the dashboard.  So yes there are some additional parts than shown in the pictures.  There is a nice racing parts shop in town that ordered the stuff and has lots of hoses, fittings, and adapters in stock so I will figure some of it out as I go.  One thing I forgot is an adapter from M10 bubble flare to -AN for the slave cylinder.
    Everything is going well with this pregnancy.  We are crazy hippies and having a midwife come for a homebirth.  We haven't done that before but neither of us is worried about it.  It is our third so not the first rodeo.
      Hippies!
        Another slight issue is that the radiator is backwards compared to the BMW one, as in the low connection is on the left and the high connection is on the right.  I have plenty of room to cross the coolant hoses in front of the engine which will solve that.  Also the Toyota engine has the "radiator cap" on top of the engine.  I plan to use an expansion tank and plumbing it similar to a stock BMW setup, I got a radiator hose temp sender adapter thing to install in the upper radiator hose but instead of a temp sensor I will put a nipple in the 1/8 NPT hole and that will be the bleed line back to the expansion tank.  Conveniently the stock radiator looks pretty solid, it has aluminum tanks too which I didn't know was a thing.
          Could you just source a radiator from another car that has dimensions and outlets that you need?
            If you'd be interested in a E34 expansion tank I have 2. Not sure what kind of space you have to work with but they mount on the firewall.
              I might be, are those similar to an e32 style where it is above the engine on the firewall?
              More pictures soon.  I got the clutch pedal/MC and a bunch of AN fittings to get through the firewall.  I got some 1/4" Cunifer tubing for a fuel return line.  There is no access door under the carpet so I have to drop the fuel tank, that should be exciting, it's about 3/4 full I think.  Yesterday after work I cut the CV axles off right by the outer joint so I could spin the cage sideways and get the balls and cage out.  I will be reinstalling just the cup part with the spindle to hold the front wheel bearings together.  They also have the tone ring for the ABS so I have a small chance of the ABS still working.
                PICTURES PLEASEEEE :wub:
                  Perfectly good CV axles chopped off.
                  O8zibaq.jpg?1
                  I might trim these off right behind the tone ring.
                  7SeYI5h.jpg?1
                  Not a ton of room trying to fit a clutch pedal.
                  ax8ZS33.jpg?1
                  And this is why I need a reverse mount, the wheel well and strut tower are so close to the firewall that there is no room at all.
                  79hHwvj.jpg?1
                    Not the number one choice but you could cut an access panel for fuel pump activities. After removing the seats and carpet it may be a wash
                      I might do that anyway, for next time. I don't know exactly where the pump is or how close to the floor it is so I was concerned about damaging hoses and wiring. It looks easy to get out thankfully.
                        Those are the front axle stubs, correct?
                        You need to take the van to a toyota dealership when its done and have them do an oil change and get it on camera. We can crowdfund it
                          Yes, I did end up parting them off in a lathe .080 past the tone ring. I installed them last night, they worked great. I've thought about what service I should ask for at a Toyota dealer. The confusion would be priceless.
                            Are you planning to run a straight axle out back or will you be fitting the rear subframe out of something?
                              Keeping the stock Toyota rear stuff for now, it was an AWD model, so time will tell how the differential and axles hold up, they look decently sturdy.
                                Ah. Here I somehow forgot and thought it was FWD. Carry on=)
                                  I cut the CV axle stubs off in a lathe.  Unsprung weight savings.
                                  JmCSCIu.jpg?1
                                  Made some cool paper weights after cleaning up the grease too.
                                  FoM9OiT.jpg?1
                                    the lathed stubs are nice!  you also need to troll siennachat.com, join up, and say that you just bought a van and ask what kind of clutch hydraulic fluid people are running in their siennas
                                      Good call, I casually mentioned it in the "What did you do to your gen 2 today" section.
                                        I dropped the fuel tank last night, what a nightmare when it is half full.  I didn't figure out until i had it on the ground how to drain it.  The fill tube enters the tank down low, it comes off but there is a check valve inside so no fuel comes out.  I couldn't see the check valve until I got the tank down.  Then I stuck a screwdriver in to hold the check valve open and tipped the whole thing to pour fuel into a drain pan a couple gallons at a time and dump it into my car.  Now I need to clean it off and figure out where to add my fuel return fitting.  I got 1/4" line for the return, I would think that is plenty?  While I have access I am going to test the pump output pressure and flow to make sure I don't need to swap in something different.
                                          1/4" sounds fine to me,
                                          I would expect the pump to be just right as it was fueling 230hp before.
                                          When are you going to splice the driveshafts together? I will be interested to see that
