<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[BMW Sienna 2.5i build]]></title><description><![CDATA[<p dir="auto">So I'm putting this in members BMWs because it has a BMW drivetrain now.  With a third kid on the way the Volvo wagon isn't big enough so my wife found a 2004 Sienna on craigslist with a bad transmission.  Got it home for 2200$ which was probably too much in hindsight.  It's an XLE Limited with AWD 172k miles.  The previous owner had a power flush done on the transmission and it plugged the filter and killed itself shortly afterward.  I was planning to get a scrapyard transmission but apparently they are hard to come by and are around 1000$ or even more for a lower mile unit.  So a friend and I pulled the engine and transmission at a shop with a lift, not really any other way to do it as it has to come out the bottom.  We got the suspension put back together and put it back on the ground to push outside while I got the transmission fixed and he says to me "hey would one of your BMW engines fit in here?".  So we got out a tape measure and figured out it was somewhat possible so let's get started!  Oh and my wife said to do whatever is cheaper, which this wouldn't be if I didn't already have an m50 with a g250 transmission sitting in my garage from my '94.</p>
<p dir="auto">The engine has an m54b30 intake cam, bored .020 over and Maxsil coated pistons, UUC lightweight flywheel with an m5 clutch.</p>
<p dir="auto">First problem is all the steering stuff in back like every transverse engine vehicle.</p>
<p dir="auto"><img src="https://i.imgur.com/L0yOFCn.jpg?2" alt="L0yOFCn.jpg?2" class=" img-fluid img-markdown" /></p>
<p dir="auto">Cleared that out by flipping the spindles, and struts left/right.  So the calipers will be behind the axle and the tie rod connection is in front.  The strut mounting, wheel bearing, and ball joint mount are in a line so it won't affect geometry.</p>
<p dir="auto"><img src="https://i.imgur.com/oggmVav.jpg?2" alt="oggmVav.jpg?2" class=" img-fluid img-markdown" /></p>
<p dir="auto">Moved all of the steering stuff and sway bar.</p>
<p dir="auto"><img src="https://i.imgur.com/CKlOPKC.jpg?1" alt="CKlOPKC.jpg?1" class=" img-fluid img-markdown" /></p>
<p dir="auto">Then I trailered the engine up to the shop, ready to get started.</p>
<p dir="auto"><img src="https://i.imgur.com/zQ1J51D.jpg?1" alt="zQ1J51D.jpg?1" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/topic/5159/bmw-sienna-2.5i-build</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:48:18 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5159.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Jan 2018 16:39:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 14 Aug 2019 20:11:50 GMT]]></title><description><![CDATA[<p dir="auto">We bought a house in June and are moved in.  I will post some pics soon.  I need to bring the van over still.  It acquired a bees nest behind the front bumper so I guess that is a sign I haven't been working on it.</p>
<p dir="auto">I bought a used but not very old 10k asymmetrical Rotary lift from a friend that was closing down his shop.  I need to drill a test hole in my garage floor to check for thickness before I figure out a plan for installation.  If the floor isn't thick enough I will add a "shop" stall to the end of the garage with a higher ceiling to accommodate the full lift height.  The existing part is 9'6" so it would still get quite a bit of height for cars but not so much for vans and trucks.  The existing garage is 26' deep by 32' wide.  It has a centered 16' door which is odd but it works.  The lift bay would have to be angled some to work with that.</p>
]]></description><link>https://wibimmers.com/post/101088</link><guid isPermaLink="true">https://wibimmers.com/post/101088</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 14 Aug 2019 20:11:50 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Mon, 18 Mar 2019 13:25:53 GMT]]></title><description><![CDATA[<p dir="auto">Glad this isnt dead. <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f601.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--grin" style="height:23px;width:auto;vertical-align:middle" title=":grin:" alt="😁" /></p>
]]></description><link>https://wibimmers.com/post/98128</link><guid isPermaLink="true">https://wibimmers.com/post/98128</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Mon, 18 Mar 2019 13:25:53 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Sat, 16 Mar 2019 14:21:55 GMT]]></title><description><![CDATA[<p dir="auto">Not really an update, but I dug the van out of the snow.  Working on figuring out wiring schematics.  The first step will be to just run the engine and later figure out what to do with instrumentation and how the van electronics will function without the ECU.  I still have a strong running 3MZ-FE if anyone needs one.  Perfect for an MR2 swap...</p>
]]></description><link>https://wibimmers.com/post/98109</link><guid isPermaLink="true">https://wibimmers.com/post/98109</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Sat, 16 Mar 2019 14:21:55 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Mon, 17 Sep 2018 14:28:48 GMT]]></title><description><![CDATA[<p dir="auto">Welcome back!</p>
]]></description><link>https://wibimmers.com/post/94557</link><guid isPermaLink="true">https://wibimmers.com/post/94557</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Mon, 17 Sep 2018 14:28:48 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Tue, 11 Sep 2018 16:43:37 GMT]]></title><description><![CDATA[<p dir="auto">Oh and add moving to the list of time usage.  I got this hauled to Wisconsin labor day weekend.  The family, hogs, chickens, and most of our stuff is moved.  Crashing at my parents house, I hear that is what cool millennial age folks are doing so I wanted to fit in.  Working on finishing things and getting the Iowa house sold.  Now I don't look so odd with my Wibimmers euro plate in the window driving around Iowa and Minnesota...  Although I still have Iowa plates on the car...</p>
]]></description><link>https://wibimmers.com/post/94419</link><guid isPermaLink="true">https://wibimmers.com/post/94419</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Tue, 11 Sep 2018 16:43:37 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Fri, 22 Jun 2018 13:36:12 GMT]]></title><description><![CDATA[<p dir="auto">Thats good to hear. I just am excited and wanted to make sure it wasnt forgotten about!</p>
]]></description><link>https://wibimmers.com/post/92757</link><guid isPermaLink="true">https://wibimmers.com/post/92757</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Fri, 22 Jun 2018 13:36:12 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 20 Jun 2018 20:31:22 GMT]]></title><description><![CDATA[<p dir="auto">I know, I've been busy with work, 3 kids, gardening, chickens, hogs, and house projects.  This will get done though.  I have been working a little here and there with getting the steering system situated.  The parts from Snap are going to work excellent.  I am working next on machining some parts for offsetting the inner tie rods up to avoid hitting the subframe.  I think it will work good, hopefully it turns out in real life like it looks in my head.</p>
<p dir="auto">The oldest and youngest chillin with the hogs.</p>
<p dir="auto"><img src="https://i.imgur.com/L2ME2Rk.jpg" alt="L2ME2Rk.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/92710</link><guid isPermaLink="true">https://wibimmers.com/post/92710</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 20 Jun 2018 20:31:22 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 20 Jun 2018 19:57:28 GMT]]></title><description><![CDATA[<p dir="auto">WE NEED MOAR VAN UPDATES.</p>
]]></description><link>https://wibimmers.com/post/92707</link><guid isPermaLink="true">https://wibimmers.com/post/92707</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Wed, 20 Jun 2018 19:57:28 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Tue, 10 Apr 2018 02:58:26 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/89865">snap said:</a></strong></p>
<p dir="auto">my gut says its easier to resist heating up with more water capacity than it is to remove heat by convection.</p>
<p dir="auto">If the cooling system isn't large enough to dissipate heat at an equal or greater rate than the engine is capable of putting out, then I think you're asking for trouble. Not that I envision this thing getting flogged continuously for a long periods of time, but adding more coolant capacity as "ballast" still seems like a half-ass solution.</p>
<p dir="auto">That being said, I'd wager that the van's stock radiator is fine.</p>
<p dir="auto">Edit: Actually, you're more likely to overheat sitting in traffic than anywhere else, due to lack of airflow. But again, extra coolant capacity might buy you a little time, but it doesn't solve the problem.</p>
]]></description><link>https://wibimmers.com/post/90459</link><guid isPermaLink="true">https://wibimmers.com/post/90459</guid><dc:creator><![CDATA[HipMF]]></dc:creator><pubDate>Tue, 10 Apr 2018 02:58:26 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Tue, 10 Apr 2018 02:18:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/90446">snap said:</a></strong></p>
<p dir="auto">This is what im sending since you cant receive pics on your potato phone. So hopefully you see this later on your toaster</p>
<p dir="auto"><a href="http://uploads.tapatalk-cdn.com/20180410/ef98a930baddc709b8ead8665d7ded41.jpg" title="Enlarge image" rel="nofollow ugc"><img src="http://uploads.tapatalk-cdn.com/20180410/ef98a930baddc709b8ead8665d7ded41.jpg" alt="ef98a930baddc709b8ead8665d7ded41.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Woah so shiny!</p>
]]></description><link>https://wibimmers.com/post/90452</link><guid isPermaLink="true">https://wibimmers.com/post/90452</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Tue, 10 Apr 2018 02:18:20 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Tue, 10 Apr 2018 02:14:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">since you cant receive pics on your potato phone</p>
<p dir="auto"><img src="https://cdn-images-1.medium.com/max/800/1*zMhfCOZSu6VdLXB7p3IKjw.gif" alt="Image result for potato phone gif" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/90449</link><guid isPermaLink="true">https://wibimmers.com/post/90449</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Tue, 10 Apr 2018 02:14:12 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Tue, 10 Apr 2018 00:38:28 GMT]]></title><description><![CDATA[<p dir="auto">This is what im sending since you cant receive pics on your potato phone. So hopefully you see this later on your toaster</p>
<p dir="auto"><img src="https://uploads.tapatalk-cdn.com/20180410/ef98a930baddc709b8ead8665d7ded41.jpg" alt="ef98a930baddc709b8ead8665d7ded41.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/90446</link><guid isPermaLink="true">https://wibimmers.com/post/90446</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Tue, 10 Apr 2018 00:38:28 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 28 Mar 2018 16:31:28 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/89864">KaiserRolls said:</a></strong></p>
<p dir="auto">People run these 24v swaps all the time with a 318 radiator.</p>
<p dir="auto">Run it &amp; see</p>
<p dir="auto">Yea, it would probably be just fine.  I have a Stewart water pump too which helps.</p>
]]></description><link>https://wibimmers.com/post/89867</link><guid isPermaLink="true">https://wibimmers.com/post/89867</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 28 Mar 2018 16:31:28 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 28 Mar 2018 16:30:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Thats a tough call. </p>
<p dir="auto">powerful stock fan + proper shrouds are a compelling argument to stay stock but my gut says its easier to resist heating up with more water capacity than it is to remove heat by convection.</p>
<p dir="auto">I was planning to use one or 2 Spal puller fans, the stock fan is PWM controlled from the Toyota ECU and is excessively thick so it would hit my water pump shaft.  I could remove the threaded end of my water pump but it's already installed.  </p>
<p dir="auto">What about this.  A tank that will add volume to the system, although I would think to install it on the cold side of the radiator and have the fan switch right at the radiator outlet.  Somewhat like an E type Jaguar.</p>
<p dir="auto"><img src="https://etypeuk.com/upload.aspx?width=1170&amp;height=0&amp;crop=auto&amp;dest=HomepageBannerImages&amp;file=banner-cooling-radiator-and-tank-behind-1.jpg" alt="upload.aspx?width=1170&amp;height=0&amp;crop=aut" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://etypeuk.com/upload.aspx?width=1170&amp;height=0&amp;crop=auto&amp;dest=HomepageBannerImages&amp;file=banner-cooling-radiator-front-1.JPG" alt="upload.aspx?width=1170&amp;height=0&amp;crop=aut" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/89866</link><guid isPermaLink="true">https://wibimmers.com/post/89866</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 28 Mar 2018 16:30:25 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 28 Mar 2018 16:12:13 GMT]]></title><description><![CDATA[<p dir="auto">Thats a tough call. </p>
]]></description><link>https://wibimmers.com/post/89865</link><guid isPermaLink="true">https://wibimmers.com/post/89865</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 28 Mar 2018 16:12:13 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 28 Mar 2018 16:08:53 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/89863">jc43089 said:</a></strong></p>
<p dir="auto">There is loads more room on the sides and about the same front to back as it was in an e36.  WAY easier to install exhaust manifolds than in an e36.  <br />
Radiator question.  The stock Toyota radiator is thin, only 7/8" core, should I just run it because the Toyota engine was a similar horsepower so it should have enough cooling capability?  The only problem I can think of is that the reduced fluid volume will not be as nice.  The BMW radiator would kinda fit but I would be making custom straps to hold it and it would not be able to quick release anyway because it is under the top of the core support rather than behind it.  Pros for keeping the stock radiator is that it fits perfect, and the shrouding for airflow is already designed for it.  I guess the fan might just cycle more with the reduced fluid volume.<br />
Thoughts?</p>
]]></description><link>https://wibimmers.com/post/89864</link><guid isPermaLink="true">https://wibimmers.com/post/89864</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Wed, 28 Mar 2018 16:08:53 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 28 Mar 2018 15:46:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/89859">snap said:</a></strong></p>
<p dir="auto">Looks like a ton of room on the sides!</p>
<p dir="auto">There is loads more room on the sides and about the same front to back as it was in an e36.  WAY easier to install exhaust manifolds than in an e36.  </p>
<p dir="auto">Radiator question.  The stock Toyota radiator is thin, only 7/8" core, should I just run it because the Toyota engine was a similar horsepower so it should have enough cooling capability?  The only problem I can think of is that the reduced fluid volume will not be as nice.  The BMW radiator would kinda fit but I would be making custom straps to hold it and it would not be able to quick release anyway because it is under the top of the core support rather than behind it.  Pros for keeping the stock radiator is that it fits perfect, and the shrouding for airflow is already designed for it.  I guess the fan might just cycle more with the reduced fluid volume.</p>
<p dir="auto">Thoughts?</p>
]]></description><link>https://wibimmers.com/post/89863</link><guid isPermaLink="true">https://wibimmers.com/post/89863</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 28 Mar 2018 15:46:02 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 28 Mar 2018 15:28:48 GMT]]></title><description><![CDATA[<p dir="auto">Looks right at home</p>
]]></description><link>https://wibimmers.com/post/89862</link><guid isPermaLink="true">https://wibimmers.com/post/89862</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Wed, 28 Mar 2018 15:28:48 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 28 Mar 2018 15:13:53 GMT]]></title><description><![CDATA[<p dir="auto">Looks like a ton of room on the sides!</p>
]]></description><link>https://wibimmers.com/post/89859</link><guid isPermaLink="true">https://wibimmers.com/post/89859</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 28 Mar 2018 15:13:53 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 28 Mar 2018 15:06:47 GMT]]></title><description><![CDATA[<p dir="auto">I got a little done last night.  I set the cam timing and installed the vanos unit and valve cover.</p>
<p dir="auto"><img src="https://i.imgur.com/m7FYCh6.jpg" alt="m7FYCh6.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">It's not gold but it should work for a daily driver.</p>
<p dir="auto"><img src="https://i.imgur.com/jVfeDaz.jpg" alt="jVfeDaz.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/post/89858</link><guid isPermaLink="true">https://wibimmers.com/post/89858</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 28 Mar 2018 15:06:47 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Tue, 27 Mar 2018 17:35:19 GMT]]></title><description><![CDATA[<p dir="auto">I can totally relate. I grew up working at my grandpa's butcher shop. <img src="/assets/uploads/files/emoticons_default_biggrin.png" alt=":D" title=":D" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/89822</link><guid isPermaLink="true">https://wibimmers.com/post/89822</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Tue, 27 Mar 2018 17:35:19 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Thu, 22 Mar 2018 18:33:35 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/89664">snap said:</a></strong></p>
<p dir="auto">City boy checking in: cannot relate <img src="http://emoji.tapatalk-cdn.com/emoji52.png" alt="emoji52.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Bacon comes from hogs, salt the belly, smoke the belly, then slice it and it's bacon.  Nom nom nom!</p>
<p dir="auto">After killing the hog you scald it in a barrel of 150ish degree water and the hair scrapes off, then gut it and hang it for a few days.</p>
]]></description><link>https://wibimmers.com/post/89688</link><guid isPermaLink="true">https://wibimmers.com/post/89688</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Thu, 22 Mar 2018 18:33:35 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 21 Mar 2018 22:39:08 GMT]]></title><description><![CDATA[<p dir="auto">City boy checking in: cannot relate [emoji52]</p>
]]></description><link>https://wibimmers.com/post/89664</link><guid isPermaLink="true">https://wibimmers.com/post/89664</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 21 Mar 2018 22:39:08 GMT</pubDate></item><item><title><![CDATA[Reply to BMW Sienna 2.5i build on Wed, 21 Mar 2018 14:48:07 GMT]]></title><description><![CDATA[<p dir="auto">Still working on the steering setup.  I did some good figuring last night.  It's been slow progress lately, with a 1 month old and butchering some hogs before it gets too warm for them to hang in the barn.</p>
<p dir="auto">Funny story, my 5 year old is helping scrape the hair off and asks "can we eat the bacon today?"</p>
]]></description><link>https://wibimmers.com/post/89652</link><guid isPermaLink="true">https://wibimmers.com/post/89652</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 21 Mar 2018 14:48:07 GMT</pubDate></item></channel></rss>
