  4. BMW Sienna 2.5i build
    The last two times I have read the thread title and just keep thinking you are building some crazy F1 tribute car to this man...
    Related image
      I too have made that mistake
        F1 engine powered van next maybe.
        I got it home.  The tow driver AAA sent was confused why I said no need to put the shifter out of park.  I just popped the hood to as an explanation.  "Oh" was all he said.
          Tow driver's inner monologue "No duramax, no care"
            Finally going to get back to this tomorrow.  I had to work all weekend last weekend.
            Thinking about instrumentation.  I have used Autometer in the past and had good results.  But populating the whole cluster will be quite pricey.  I do see that the digital gauges from Autometer are somewhat cheaper than full sweep gauges because they don't need the stepper motor mechanism.  I don't care for a digital tach though, maybe digital everything else and analog tach.  Any other thoughts?
            Also going to try to get the clutch pedal area measured up so I can figure out what to buy for that.
            I'm wishing I had insulation in my garage, also being interrupted by "nesting"  about 2 weeks until baby is due.
              Does it not have a factory tach? Why not stick with the factory gauges? I know that aftermarket stuff is more precise but I would think you would want to keep this as stock as possible inside?
                It does have a tach in the factory dash.  I haven't dug into the wiring diagrams much yet for the Toyota but I assumed it was canbus from ECU-Dash.  If not then maybe I can drive the tach with the BMW signal.  The speedometer signal came from a sensor in the transmission.  Maybe I could mount it to a custom bracket and look at a tab on the driveshaft.  I will have to see what the relation of speed would be compared to what it was looking at inside the transmission.
                I got it in the garage this weekend and up on jack stands.  Installed N54 studs and OBD2 exhaust manifolds.  There is much more room than in an e36 which is nice.
                  probably tons easier than working on the original V6 too.
                    This too.  You can't even change spark plugs on the 3mz without removing the intake manifold.
                      I did it once without pulling the manifold. the last 2 were horrible
                      • stealthbimmerS
                        stealthbimmerS
                        stealthbimmer
                        :lol::rolleyes: You have one of those as well?
                        1997 328ic
                          yup, this is number 3.  Hence the van for kid hauling.
                          • stealthbimmerS
                            stealthbimmerS
                            stealthbimmer
                            Twinsies....although we got the van before the second one. Mine isn't bmw powered though.
                            1997 328ic
                            • basedspiderB
                              basedspiderB
                              basedspider
                              Definitely looking forward to watching this build enfold.
                                Ordered a bunch of Willwood parts for the clutch pedal setup.  I need to modify the brake pedal bracket to get a little room and move the pedal over about 2 inches and trim it narrower.  The reverse swing mount pedal is necessary because there is no room on the other side of the firewall from where the pedal needs to be.  The strut tower is hardly an inch away.
                                The warmer day yesterday was nice, I got a couple hours of work done after the kiddos were in bed.  My wife's due date is tomorrow so baby is coming anytime.
                                  I didn't even think about the clutch pedal situation. By the way the pedal bracket looks, the MC will be mounted inside the car with the fluid reservoir inside the car also, is this correct?
                                  Hope everything is well for you guys tomorrow and if nothing else, that everybody is calm and relaxed.
                                    The MC will be inside facing back, I ordered a -4AN bulkhead to get through the firewall and an adapter for the MC inlet to -AN so I can put the reservoir in the engine bay.  It would be a pain to check/fill under the dashboard.  So yes there are some additional parts than shown in the pictures.  There is a nice racing parts shop in town that ordered the stuff and has lots of hoses, fittings, and adapters in stock so I will figure some of it out as I go.  One thing I forgot is an adapter from M10 bubble flare to -AN for the slave cylinder.
                                    Everything is going well with this pregnancy.  We are crazy hippies and having a midwife come for a homebirth.  We haven't done that before but neither of us is worried about it.  It is our third so not the first rodeo.
                                      Hippies!
                                        Another slight issue is that the radiator is backwards compared to the BMW one, as in the low connection is on the left and the high connection is on the right.  I have plenty of room to cross the coolant hoses in front of the engine which will solve that.  Also the Toyota engine has the "radiator cap" on top of the engine.  I plan to use an expansion tank and plumbing it similar to a stock BMW setup, I got a radiator hose temp sender adapter thing to install in the upper radiator hose but instead of a temp sensor I will put a nipple in the 1/8 NPT hole and that will be the bleed line back to the expansion tank.  Conveniently the stock radiator looks pretty solid, it has aluminum tanks too which I didn't know was a thing.
                                          Could you just source a radiator from another car that has dimensions and outlets that you need?
