521 Posts 25 Posters 1 Views 1 Watching
    Dang, you're making the rest of us look bad with all this progress!
    All that healthy asparagus eatin'
      Man I've got to learn how to weld.  Nice job!
        Looks good!
          Looks awesome, much congrats on tons of progress. Please take some nice close ups of that dash when its ready to go back into the car!
          • AsparagusMikeA
            AsparagusMikeA
            AsparagusMike
            Sorry for the late update. Spent the whole last week in Arizona enjoying the beautiful warm weather. Before I left I was able to finish up a couple things.
            After getting my timing cover gaskets in the mail as well as many other parts needed for the motor I got the timing cover back on and gave the upper timing chain tensioner bolt another shot at redemption... Success acheived :D
            Not to long after, my buddy showed up and went at it finishing welding the reinforcement on the rest of the subframe pieces...
            That was about it until I got back this last weekend. The following morning woke up, ate some asparagus, and began tearing apart the steering rack for rebuild...
            Once it was dissembled, threw it in the wash tank for a good 2 hours for a thorough cleaning.
            Would have the rack already back together by now but I have been struggling and struggling to get the last main seal in the middle of the rack housing out but nothing seems to be working.
            So far I have tried removing the seal with a bushing remover kit which ended real quick as it seemed I was stuck in between two different sizes that was either to small or to big to grab the seal. Tried using a wooden dowel as well as a long thin punch and screwdriver which only got me breaking off the plastic molding pieces behind the bushing that are suppose to come out with it and be replaced.
            That was pretty much all I had for an edge to tap on. Now it seems anything I try to tap on the back of the bushing slips off. At this point I am pretty much stumped and took a break from the whole thing for a bit so I don't lose my mind.
            On the up side... bushings showed up!
            As for other things accomplished... designed up a new gas pedal bracket today to replace the unsalvageable rusty old one. Checked it on the pedal itself to verify proper fit and then welded her into place at the same location as the original.
            Between school and work lately it has been hard to get over to the shop and get anything done. Hoping to get a break this weekend and crank out a few things.
            Things up next on the agenda include...
            1. Get the holes for the alignment cams on the rear sub frame opened up to the same shape as the brackets installed.
            2. There are three more small holes ate through by rust that need to be cut out and welded.
            3. Once the above two are completed, POR-15 everything.
            4. Work on getting the seal out of the rack
            5. Start working on getting the carpet cleaned up.
            6. Make up new brake and fuel hard lines to be installed as well as ordering the brackets which I seemed to have forgotten about getting on the last order.
            7. Continue to work on getting the seal out of the rack
            8. Begin working on cleaning up the gas tank.
            9. Throw steering rack away and buy a re manufactured one like I should have in the first place instead of fucking around with this one.
              I wasnt aware some of those reinforcements existed, I only have a few of those. What is your spring and damper situation?
              • AsparagusMikeA
                AsparagusMikeA
                AsparagusMike
                Some of it may a bit overkill, whatever. I'm running BC racing coilovers, spring rates are 6k in the front and 10k in the back (Stiffness is pretty close to the same of what H&R race springs would be).
                  Did you form or purchase the plate that is welded in the open area of the rear trailing arm?
                  I've been wanting to do something similar as a "skid plate" for the lifted car lol.
                    Garagistic makes them
                    • AsparagusMikeA
                      AsparagusMikeA
                      AsparagusMike
                      I'm sure a lot of you guys have heard of or are familiar with the whole rx7 caliper bbk for the e30, whats ur opinions on it? Any experiences with the setup?
                        I run brembo blanks, stock calipers, good pads and fluid, stainless lines, etc - I have yet to find myself needing more brake for regular driving and for autocross.
                        What are your plans for the car?
                        • AsparagusMikeA
                          AsparagusMikeA
                          AsparagusMike
                          Well hopefully find my way into doing some auto-x/track events as well as enjoying it occasionally on the weekends driving around to meets and what not. On what I've read up and researched, people that have done the conversion say that when tracking the car the brakes are quite a bit better over the stock calipers with the same pads and the longevity of the pad life increases substantially. Also, the conversion itself is so so simple and inexpensive that I almost feel its worth giving it a try.
                            The biggest downside to the rx7 brakes is that you are then stuck with using specially machined rotors, which isn't a big deal if you have spares on hand, but you can't overnight something off the shelf if you ever need one in a pinch and they're going to be generally more expensive. If you're tracking the car the bigger brakes will deal with heat better, but as long as you can lock up your tires (which you can on stock brakes), bigger brakes won't necessarily stop you any sooner than stock rotors and good pads.
                              I thought you run corrado rotors?
                                ^ Yeah, with the center-bore opened up 1mm.
                                I had built a set of them, but they didn't fit under my wheels so I sold em.
                                A friend had them on his car and seemed to have serious lock up "issues", like his modulation was negatively affected.
                                A good high carbon rotor and good pads had always treated me very well. (Centric rotors(stoptech) and Hawk/EBC pads)
                                  Maybe try the autox/track events first with the car to see if you need the upgrade? You won't for street driving and unlikely for parking lot autox. Once you get more comfortable with the car and learn how to be faster with it on the track you might. For an e30 the combination of brake lines and hoses in good shape, stock blanks, high temp fluid (ATE, Motul) and brakes properly bled, race pads (PFC 08/11, Hawks HT-10 or DTC 60/70), sticky tires, and proper braking technique go a long way. With the above the only stopping issues on track I've had are when I've overcooked a corner by going in way too deep with too much speed before braking, or when a car in front of me dumped fluids/oil.
                                  • AsparagusMikeA
                                    AsparagusMikeA
                                    AsparagusMike
                                    Alright, for now I'll stick with the e30 calipers, invest in better pads and rotors, and upgrade later if needed. I am considering of still switching over to a master cylinder from a e32 750i as it is said to have a stiffer feel from the pedal.
                                    So, originally I had planned to rebuild my own calipers but now that I look at what it costs to buy a reman'd one, I might as well go that route. Is there any reason I should switch over to the ate calipers vs. sticking with the girling? I understand that with the brass bushings they are suppose to have a better feel... any experiences with those as well?
                                      The master cylinders and calipers are paired together. You can mix and match, but your mechanical advantage may not be what its supposed to be. There is no reason to switch to the ATE and brass slide bushings in my opinion. this is a good resource if you havent already come across it
                                      http://www.massivebrakes.com/
                                        If you go with brass, keep up with cleaning them so they don’t bind.
                                          Can’t comment on the ATE calipers, but I bought rebuilt rear girling calipers from centric last year after snapping a bleed screw and I have nothing bad to say about them, they seem to be pretty good value for the money. If you care about how they look, make sure to get paint on them ASAP, they start to get surface rust pretty quickly.
