  4. Das Vert
Das Vert
32 Posts 9 Posters 0 Views 1 Watching
  • stealthbimmerS
    stealthbimmerS
    stealthbimmer
    Been kind of at a stall with this. Was hoping my brother would put his damn audi back together so I could have access to the lift for my swap. That doesnt look like it is happening in the near future.
    So, I at least decided to get the swap parts together, so when and if I get access to the lift I am ready to go. Soon enough I will just bite the bullet and do it on jack stands. I did it with my e34, I would just rather not do it again.
    I have found this is the easiest way to remove a drivetrain from parts cars. I much prefer working on my feet than on my back under a rusted out hoopdie.
    I picked away at it a bit, but I am going to let most of the bolts soak overnight doused in pb blaster. Half the exhaust bolts snapped, so I would rather be safe than sorry with the axle bolts. I have rounded off enough of those in my day.
    1997 328ic
      I love it.
        Excellent
        • stealthbimmerS
          stealthbimmerS
          stealthbimmer
          Had to improvise. With no brakes or wheels on the ground to stop the axles from spinning, how to remove the cv joint bolts was eluding me....took me awhile to figure out something that worked.93bd423c55290f052f53890121c5776a.jpg
          1997 328ic
            How did the spare tire well get so smashed in?
            • stealthbimmerS
              stealthbimmerS
              stealthbimmer
              Beats me. It's rotted out. Actually the whole car is rotted out...this thing has seen some shit. I may of gotten more smashed when the car fell off the forks when I was flipping it on its side. It's so rotted it was hard to find a solid area to lift.
              1997 328ic
              • stealthbimmerS
                stealthbimmerS
                stealthbimmer
                1997 328ic
                  Are you referring to the bearing falling out on its own or the milled bolt heads?
                  Looks good to me.
                  • stealthbimmerS
                    stealthbimmerS
                    stealthbimmer
                    Looks good to me.
                    Both
                    I really want to know what happened to this car. There is no way it was road worthy any time in the near past. The rear trailing arm wasn't even attached. There had to of been 27 different vacuum leaks that I discovered while disassembling the intake area....and a hack job m50 manifold swap. Now this.
                    Here is to hoping this trans actually works properly once I get it in the other car. I know the zf 5spd is pretty robust, but it appears this car has been used, abused, and put away rusted to shit. 2d2d64afe575833c911faa23292da06d.jpg
                    1997 328ic
                      Yeah, like I said, I was surprised to see that car was anywhere but a junkyard. It was rough when I sold it years ago.
                      Fingers crossed that the trans is in good shape. The clutch was toast when I sold it, but all of the mechanics worked fine.
                        Must have just sat somewhere for a long period of time.
                        • stealthbimmerS
                          stealthbimmerS
                          stealthbimmer
                          I'm just as surprised. Well, it will be meeting the crusher in the near future
                          1997 328ic
                          • stealthbimmerS
                            stealthbimmerS
                            stealthbimmer
                            Alright got everything I need from underneath. Just need to pull the pedal box c57305e6b710a5a11265ee69df28cf81.jpg1a7772e54a5cfddb456fea1c621d74f5.jpgd68c2c0f3810ac0fb1a6375199dead9a.jpg
                            1997 328ic
                            • stealthbimmerS
                              stealthbimmerS
                              stealthbimmer
                              Not much to update. Still procrastinating hoping the lift will become available... I have pretty much everything ready to go for the swap. I just need to clean everything up and replace all the wearable parts, oh and a clutch/flywheel
                              Finally found some reasonably priced (still ridiculous for two little metal brackets and some wire) hardtop mountsef2f9608dc25a56606a272c78a241d04.jpg
                              1997 328ic
                                Awesome hardtop! How heavy is it? Is it something you can install and remove by yourself if you are all hopped up on Diet 7up?
                                • stealthbimmerS
                                  stealthbimmerS
                                  stealthbimmer
                                  It's not heavy. Maybe 50-60lbs. It's a bit big and akward to try to manhandle by oneself... I would rather not damage the pins on the top of the car itself. I will eventually put a pulley lift in my garage to lift it on/off
                                  1997 328ic
                                    Awesome! Hardtops are sweet.
                                    • stealthbimmerS
                                      stealthbimmerS
                                      stealthbimmer
                                      Oh yea, I also swapped the seats. Stock seats were in bad condition. Parts car seats were in good condition. Granted, they aren't the right color, but I have a habit of building cars with an identity crisis. They will have to do until I can find some clean tan replacements. Only takes 10 minutes to swap them out.8dc1f70702fe00b73b7024292b435ef5.jpg
                                      1997 328ic
                                        You could always do a whole interior redye. It would be a huge undertaking but if you like black interior it may be worth it!
                                        (Its also something you could do while waiting for the lift)
                                        • stealthbimmerS
                                          stealthbimmerS
                                          stealthbimmer
                                          Ive thought about it. Not sure its something I want to tackle. If I found a full donor interior I would do the swap, but I dont want to dye. The rear seats have some seams separating, and the door cards/rear seat sides arent in the best shape on the top edge from, what I assume is, sun damage. Hard to find vert parts though.
                                          1997 328ic
