  4. Das Vert
Das Vert
32 Posts 9 Posters 599 Views 1 Watching
  • stealthbimmerS
    stealthbimmerS
    stealthbimmer
    I love yellow lights on an e36!
    I love em on everything....even my truck
    1997 328ic
      cheap builds are fun to follow too, looking forward to more!
        ❤️❤️❤️ that e34
        • stealthbimmerS
          stealthbimmerS
          stealthbimmer
          I'm a fan (maybe because I'm broke). I wasn't even looking for a car but this thing popped up in my fb feed one night. Couldn't pass it up. Happy to be back in the game
          Although I'm not sure how "cheap" it is anymore
          1997 328ic
          • stealthbimmerS
            stealthbimmerS
            stealthbimmer
            1997 328ic
            • stealthbimmerS
              stealthbimmerS
              stealthbimmer
              [emoji173]️[emoji173]️[emoji173]️ that e34
              Miss it every day,she was my pride and joy. My first legit "build" [emoji17]
              My favorite bimmer I have owned by far,and I've owned many. It was damn quick for being a 5er.... many surprised faces
              1997 328ic
                stealthbimmer said:
                Miss it every day,she was my pride and joy. My first legit "build" emoji17.png
                My tired brain read this as "many surprised feces" and it still made sense to me.  Be it a lot more humorous imagining surprised feces!
                • stealthbimmerS
                  stealthbimmerS
                  stealthbimmer
                  Been kind of at a stall with this. Was hoping my brother would put his damn audi back together so I could have access to the lift for my swap. That doesnt look like it is happening in the near future.
                  So, I at least decided to get the swap parts together, so when and if I get access to the lift I am ready to go. Soon enough I will just bite the bullet and do it on jack stands. I did it with my e34, I would just rather not do it again.
                  I have found this is the easiest way to remove a drivetrain from parts cars. I much prefer working on my feet than on my back under a rusted out hoopdie.
                  I picked away at it a bit, but I am going to let most of the bolts soak overnight doused in pb blaster. Half the exhaust bolts snapped, so I would rather be safe than sorry with the axle bolts. I have rounded off enough of those in my day.
                  1997 328ic
                    I love it.
                      Excellent
                      • stealthbimmerS
                        stealthbimmerS
                        stealthbimmer
                        Had to improvise. With no brakes or wheels on the ground to stop the axles from spinning, how to remove the cv joint bolts was eluding me....took me awhile to figure out something that worked.93bd423c55290f052f53890121c5776a.jpg
                        1997 328ic
                          How did the spare tire well get so smashed in?
                          • stealthbimmerS
                            stealthbimmerS
                            stealthbimmer
                            Beats me. It's rotted out. Actually the whole car is rotted out...this thing has seen some shit. I may of gotten more smashed when the car fell off the forks when I was flipping it on its side. It's so rotted it was hard to find a solid area to lift.
                            1997 328ic
                            • stealthbimmerS
                              stealthbimmerS
                              stealthbimmer
                              1997 328ic
                                Are you referring to the bearing falling out on its own or the milled bolt heads?
                                Looks good to me.
                                • stealthbimmerS
                                  stealthbimmerS
                                  stealthbimmer
                                  Looks good to me.
                                  Both
                                  I really want to know what happened to this car. There is no way it was road worthy any time in the near past. The rear trailing arm wasn't even attached. There had to of been 27 different vacuum leaks that I discovered while disassembling the intake area....and a hack job m50 manifold swap. Now this.
                                  Here is to hoping this trans actually works properly once I get it in the other car. I know the zf 5spd is pretty robust, but it appears this car has been used, abused, and put away rusted to shit. 2d2d64afe575833c911faa23292da06d.jpg
                                  1997 328ic
                                    Yeah, like I said, I was surprised to see that car was anywhere but a junkyard. It was rough when I sold it years ago.
                                    Fingers crossed that the trans is in good shape. The clutch was toast when I sold it, but all of the mechanics worked fine.
                                      Must have just sat somewhere for a long period of time.
                                      • stealthbimmerS
                                        stealthbimmerS
                                        stealthbimmer
                                        I'm just as surprised. Well, it will be meeting the crusher in the near future
                                        1997 328ic
                                        • stealthbimmerS
                                          stealthbimmerS
                                          stealthbimmer
                                          Alright got everything I need from underneath. Just need to pull the pedal box c57305e6b710a5a11265ee69df28cf81.jpg1a7772e54a5cfddb456fea1c621d74f5.jpgd68c2c0f3810ac0fb1a6375199dead9a.jpg
                                          1997 328ic
