1.6k Posts 49 Posters 0 Views 1 Watching
    BMWben said:
    Amen to that! Once you go V8, you never go back. #V8Mafia
    That doesn't rhyme...
      You guys talking about the vegetable juice? Go make a vegan thread elsewhere
      • TehRaydarloverT
        TehRaydarloverT
        TehRaydarlover
        https://minneapolis.craigslist.org/hnp/pts/5960595171.html
        • BMWbenB
          BMWbenB
          BMWben
          Put it in a Geo
          BMWCCA #499464
            /thread633286040062d3ab1d5cfd97d30dc86d.jpg2cf0ba490abdf4059e120f485c033c98.jpgfe9504b2e324556847fc1155bf6a388a.jpgdefa1338ecc4eccde98f41443aed8b66.jpgfff80694429626c7c8c41481cb19defb.jpg5b38b1aa6a591fb885ad473fff110d21.jpg
              Some nice looking parts you have there!
              I recognize that work bench
                What cam did you go with?
                    Wow, not messing around!  Nice progress!
                      Motor is back! Flywheel is on. Waiting on the wiring harness. The wheels are in motion!a1419b589c9da83e50f73986ccf605f0.jpg1ac3702e17fda4033d94e4f4f80afdac.jpg0418998545dc088ed0589caa8e7e98d9.jpga016da2e1ec5b5bbc73f88d443484e5a.jpge98ff056dbd70010aaecf53dade545ee.jpg
                        Are those quick-disconnects on the fuel lines?
                          Kinda, -6AN fittings attached to a stock filter/regulator. See pic.
                          Making new fuel lines with my new 37 degree AN flare tool! Super easy but haven't mastered my bends yet.
                          Fuel Feed: Tank -> 4-6" of 3/8" rubber hose -> barbed fitting -> -6AN Male -> -6AN Female -> 2' of 5/16 Steel fuel line -> -6AN Female -> -6AN Male attached to input of Fuel filter/pressure regulator -> -6AN Male attached to output Fuel filter/pressure regulator -> 4' of 5/16 Steel fuel line -> -6AN Female -> -6AN Male -> braided fuel line -> -6AN fuel rail adaptor -> LS3 Fuel Rail (Needed to use to fit MSD Atomic AirForce Intake) -> DEKA 60lbs injectors
                          Fuel Return: Tank -> 4-6" of 3/8" rubber hose -> barbed fitting -> -6AN Male -> -6AN Female -> 2' of 5/16 Steel fuel line -> -6AN Female -> -6AN Male attached to return of Fuel filter/pressure regulator
                          Thinking about putting a pressure gauge in the engine bay for easy trouble shooting.0dbb8f6cbcf1d0b74742cdda01544483.jpg
                            You should. They are cheap and will save you some guess work down the road! Glad to see you making good progress. Keep on hammering through 😁
                              You should. They are cheap and will save you some guess work down the road! Glad to see you making good progress. Keep on hammering through [emoji3]
                              I'm trying. With a 6 month old I have 30 min here, 2 hours there. I'll pick it up!
                                Someone change this mans thread title!!
                                  Glad to see some updates!
                                    I've conformed to the LS world and lost all creativity. Suggestions?
                                      Buttoned up the fuel system!
                                      80-3888479195550bef7fd91bde32433cb61c
                                      80-38884789855c23917af9ebaaa2e2538aaf
                                      80-249137203575db2d9571bbc4b49e17690c
                                      80-2800540350973ebe0d67fbd073127871b6
                                        glad i'm not the only one who's frame rail looks disregarded :lol:
                                        those new lines are oh so tidy. *thumbsup
                                          I want to weld a 1/4" thick plate to my jack points so i dont feel as bad about things
                                          Looks good man! Does the LS require larger fuel lines? I can now gladly say that i have now seen one of those 135 degree bend AN fittings in use. Are the lines aluminum? I wouldnt think steel would be uncoated.
