Chapter GMW | E30 LS1 (starting on post #1427)
Amen to that! Once you go V8, you never go back. #V8Mafia
That doesn't rhyme...
You guys talking about the vegetable juice? Go make a vegan thread elsewhere
/thread
LMT Stage 4
Wow, not messing around! Nice progress!
Motor is back! Flywheel is on. Waiting on the wiring harness. The wheels are in motion!
Are those quick-disconnects on the fuel lines?
Kinda, -6AN fittings attached to a stock filter/regulator. See pic.
Making new fuel lines with my new 37 degree AN flare tool! Super easy but haven't mastered my bends yet.
Fuel Feed: Tank -> 4-6" of 3/8" rubber hose -> barbed fitting -> -6AN Male -> -6AN Female -> 2' of 5/16 Steel fuel line -> -6AN Female -> -6AN Male attached to input of Fuel filter/pressure regulator -> -6AN Male attached to output Fuel filter/pressure regulator -> 4' of 5/16 Steel fuel line -> -6AN Female -> -6AN Male -> braided fuel line -> -6AN fuel rail adaptor -> LS3 Fuel Rail (Needed to use to fit MSD Atomic AirForce Intake) -> DEKA 60lbs injectors
Fuel Return: Tank -> 4-6" of 3/8" rubber hose -> barbed fitting -> -6AN Male -> -6AN Female -> 2' of 5/16 Steel fuel line -> -6AN Female -> -6AN Male attached to return of Fuel filter/pressure regulator
Thinking about putting a pressure gauge in the engine bay for easy trouble shooting.
You should. They are cheap and will save you some guess work down the road! Glad to see you making good progress. Keep on hammering through
You should. They are cheap and will save you some guess work down the road! Glad to see you making good progress. Keep on hammering through [emoji3]
I'm trying. With a 6 month old I have 30 min here, 2 hours there. I'll pick it up!
Someone change this mans thread title!!
I've conformed to the LS world and lost all creativity. Suggestions?
Buttoned up the fuel system!
glad i'm not the only one who's frame rail looks disregarded
those new lines are oh so tidy. *thumbsup
