  3. BMW Discussion
  4. Wheel refinishing
Wheel refinishing
style 42
27 Posts 5 Posters 470 Views 1 Watching
    So do the face bolts thread into the barrels? Did you try using heat? Getting all those snapped bolts out of there is gonna suck if they are still in the barrel.
    As far as removing the face I would just use wood, a foam floor tile and work around the perimeter until its off. Or make a jig like this guy LOL:
      scrap aluminum alloy wheels are something like $0.50/lb
      with the weight of these boat anchors, your looking at $40-50 if you scrap these.
        • stealthbimmerS
          stealthbimmerS
          stealthbimmer
          Yes bolts thread into barrel. I tried heat. The bolts that broke were going to brake no matter what. They are just that corroded. If I can ever actually get a face off I will see if the snapped bolts are even removable. At this point I am likely just writing them off as a lost cause.
          1997 328ic
          • stealthbimmerS
            stealthbimmerS
            stealthbimmer
            Hey atleast I would get the $50 I paid for them back
            1997 328ic
              *Cough* Someone *Cough* Should do this *Cough*
                https://www.bimmerforums.com/forum/showthread.php?2148128-Anyone-removed-a-stripped-or-broken-bolt-from-a-two-piece-wheel-(Style-42-or-71)
                • stealthbimmerS
                  stealthbimmerS
                  stealthbimmer
                  None of my bolt heads stripped.
                  1997 328ic
                    It says "or broken" right in the title lol. I was posting it just to show that you can buy new bolts and that they're surprisingly titanium.
                      nice link Earl!
                        If u are planning on scraping them I might try to buy one from you to make that a PC case like I showed above. Need to take measurement of my stuff though.
