  3. BMW Discussion
  4. Wheel refinishing
Wheel refinishing
style 42
27 Posts 5 Posters 470 Views 1 Watching
  • stealthbimmerS
    stealthbimmerS
    stealthbimmer
    They're Fittipaldis=) Corvette fitment I assume?
    They are indeed fittipaldis.
    17x8.5 I believe
    5x120 et13
    I think I have only come across like one other set with the same specs. They need to be finished though. I have the faces stripped and the lips sanded. Two barrels have bends or cracks so I need to get those taken care of before anything. I have been sitting on them for years.
    1997 328ic
    • stealthbimmerS
      stealthbimmerS
      stealthbimmer
      Welp. Only one wheel let me have its bolts free of charge. As for the others, they were snapping even with only using the breaker bar. I even tried heat first....they were destine to break. Anyways, I said F it and just took the impact to them all.
      This was the end result
      7Rh9CAz.jpg?1
      So, not sure what I am going to do with these at this point. I still havent been able to get a face seperated from a barrel. So, if I cant even do that, nothing is going to happen. Worst case scenario is Im out $50 and I plastidip the one good one and hang it on a wall or something.
      1997 328ic
        So do the face bolts thread into the barrels? Did you try using heat? Getting all those snapped bolts out of there is gonna suck if they are still in the barrel.
        As far as removing the face I would just use wood, a foam floor tile and work around the perimeter until its off. Or make a jig like this guy LOL:
          scrap aluminum alloy wheels are something like $0.50/lb
          with the weight of these boat anchors, your looking at $40-50 if you scrap these.
            • stealthbimmerS
              stealthbimmerS
              stealthbimmer
              Yes bolts thread into barrel. I tried heat. The bolts that broke were going to brake no matter what. They are just that corroded. If I can ever actually get a face off I will see if the snapped bolts are even removable. At this point I am likely just writing them off as a lost cause.
              1997 328ic
              • stealthbimmerS
                stealthbimmerS
                stealthbimmer
                Hey atleast I would get the $50 I paid for them back
                1997 328ic
                  *Cough* Someone *Cough* Should do this *Cough*
                    https://www.bimmerforums.com/forum/showthread.php?2148128-Anyone-removed-a-stripped-or-broken-bolt-from-a-two-piece-wheel-(Style-42-or-71)
                    • stealthbimmerS
                      stealthbimmerS
                      stealthbimmer
                      None of my bolt heads stripped.
                      1997 328ic
                        It says "or broken" right in the title lol. I was posting it just to show that you can buy new bolts and that they're surprisingly titanium.
                          nice link Earl!
                            If u are planning on scraping them I might try to buy one from you to make that a PC case like I showed above. Need to take measurement of my stuff though.
