  4. Fancy Stancy 325is
Fancy Stancy 325is
193 Posts 17 Posters 0 Views 1 Watching
    It looks like this, the red thing in front is the heat exchanger housing.  It has a brass plate type element inside that the raw water goes through with coolant surrounding it.
    fetch?id=7165377
      So the car has been driving great other than water filling up the cylinder 5 and 6 spark plug wells after a big rain.  It did it even with the beauty cover installed...  I guess I need to run the hose on it and watch where water is going.  the rubber ring that somewhat seals around the outside of the hole for the oil fill is missing so maybe the water is running onto the oil fill cap and then under the cover?  It seems far fetched but it happens pretty much every heavy rain storm.
        Just saw the post about the boat heat exchanger. Where's the dislike button when you need it??
        Different chassis, but, the "elephant trunk" drain on the e30 firewall is responsible for similar behavior on a 24v e30. Whatever collects in the rain tray needs to drain through the elephant trunk instead of dumping onto the valve cover
          The boat is running great as of Saturday night, very late...  I had replaced the timing belt, engine water pump, seals on the front of the engine etc.  Then I couldn't get it to start, not even a pop.  So I installed the marine electric fuel pump that I had bought a while back, now I had fuel to the carb, still no start though.  So I took the carb apart and cleaned it, 44mm solex downdraft, it had some dirt in it but the jets looked good.  Still no start...  Double checked the timing belt because it drives the intermediate shaft for the distributor, everything lined up perfect.  I double checked the plug wires are installed correctly.  That looks great according to FSM.  I removed the distributor cap to see if I had somehow installed the rotor wrong, hmm it is not pointing to cylinder one when at TDC...  After rotating all of the plug wires clockwise one spot it runs perfect.  Apparently someone installed the distributor turned 90 degrees long ago and I never looked when disassembling it because it ran fine.  I learned my lesson on that lol.
          Good thought on the drain.  It is probably clogged with leaves and junk.  I will check that tonight.
            I checked it out at lunch time, the drain was totally clogged with rotten leaves and twigs.  The next rain storm will test if that fixed it.
              Boat is sold!  More money for the shop!
              I took the first long distance trip of the e36, 600 miles round trip to Road America last weekend for the Hawk vintage races, it exposed a few slight issues.  The bolts came loose on one exhaust flange to the catback, I will use locknuts next time.  I think the added heat blowing around under the car caused the fuel line to start leaking slightly at the pump, just enough to smell fuel and stop the car to unload the whole back seat to get a look.  A good reminder to replace the rubber fuel lines and pump/sender gasket rings.  And it was spreading oil everywhere causing an awesome burning smell, I thought it was coming from the transmission because I filled it before leaving but I figured out that it is engine oil leaking around the dipstick tube.  I didn't pull the dipstick yet but I am guessing the oring is junk or not even there.
              On the upside I did not have any water in the spark plug holes after the last rain storm so the drain being plugged was causing the issue.  And I got 27 mpg driving to RA, calculated mpg not from OBC.  The OBC reads slightly more optimistic because the injectors flow a couple % more than it is calibrated for.
              I am working on figuring out what to do to escape from the photobucket nightmare.  What a pain.
                Just driving it.  Hit 278k this weekend.  Other than my old truck this is our only car right now because the Volvo is all taken apart.  The rear tires rub a little when it's loaded with groceries and kids in the back!
                  original rings, bearings, and valvetrain that you know of ?
                    Your wife must be a saint.
                      The vin tags match and it is so filthy that I am pretty sure it has never been opened.  I have some new cooling system parts to put in when I get time.  It does burn/leak a little oil.  Around a quart every 1500 miles I think.  No big deal.
                      I know, she wanted me to work on the Volvo and get that sold before I fix her new van lol.  Her main problem with it is that the power steering works about 25% of the time so parking lots are tricky.  It's weird because sometimes it feels normal and other times there is no assist at all.  Maybe the relief valve is sticky?  It is better than when I first started driving it but still not great.
                        That's not much different than my e36 with half the mileage, I'd say you're doing pretty well!
                          I just ordered some General Altimax Arctic snow tires in 205/60R15 to mount on some bottle caps for the winter, bring on the snow!  They were a closeout on Tirerack, total including shipping 329.72 and then a 50$ rebate so 279.72 for a set of snow.  I have always run Blizzaks but I have heard good things about the General tires so I will see for myself.
                            That's a great deal! I have those tires for my e36 and they're fantastic, especially for the price.
                              Not sure if it's too late to cancel your order, but if you want to save another $70 here ya go. The dual rebate is quite nice, and they have free shipping.
                              https://www.discounttiredirect.com/buy-tires/general-altimax-arctic-studdable/p/26128
                              Use their online chat to get them ordered, they are getting more in soon, so I would assume you can get that size.
                              They are stellar tires for sure!
                                You'll like the Altimax Arctics. I've had them on many cars and they were great. Wish I could get them in 18" for my 335i daily, but settled on a new set of Bilzzaks.
                                  Can confirm they are good
                                    Good deal, they should be plenty good for hooning to work an back!  Everyone thinks I will have a terrible time in my "little car with RWD"  When I always made it in the Maxima + Blizzaks before even when pushing snow with the bumper, and the guys with 4wd trucks are late...
                                      Hit 280k.  Oil change this weekend.  Snow tires are on, looking sexy with my bottlecaps.  I installed center m3 front control arm bushings.  Installed my UUC poly RTAB bushings from my other car, the ones in there were toast.  I found a stuck in the nut but not tight bolt on the rear left lower control arm where it connects to the subframe so I will cut that out and replace it.  Adjustable lower control arms which is nice.  I got 3 of the 4 adjustments freed up and anti-siezed, I just disconnected one end of the arm with a stuck end and turned that end twice as many turns.  Took my camber from about -2.8 degrees to about -1.5.  That should improve tire life and doesn't look as terrible with stock wheels and pulled fenders.  Coming in the mail today is a new ball joint for the rear upp.  It has quite a bit of wobble to it.  Hopefully get that done this weekend.
                                        Nice bit of maintenance=) I always laughed because of how silly my coupe looked with stock wheels on due to -5º of camber all around
                                          Changed the oil, rebuilt the shifter linkage which turned out to be a mess.  The shifter I think is just a modified factory shifter, maybe from a z3, but the bottom had been machined for a couple bearings the were partly disintegrated and all the balls were gone.  I replaced the front shifter carrier bushings with delrin from Garagistic, and the rear bushing I cut all of the rubber out and installed the poly bushing from Garagistic.  I jumped on their black friday sales.  The rear poly is very hard durometer and was too big to allow the spring clip to go in so I had to sand some off with a belt sander, it is still really tight.  I drilled out the bottom of the shifter itself and turned a brass bushing to press in.  Then put it all together with my UUC Motorwerks DSSR.  It's tight now.  The only thing better I think would be a floor mount shifter with no carrier.  I took some pics but I need to find my Flikr password...
