  4. Fancy Stancy 325is
Fancy Stancy 325is
193 Posts 17 Posters 0 Views 1 Watching
    Gotta use up them tows
      It's almost halfway through the year
        Yep! I've only used one this year so far.
          I made a "bushing" from stainless steel and Nylatron which is a lubricant embedded nylon, because it was in the cutoff pile at work not really for any special reason.
          The fit turned out great into the subframe, I could have gone 1-2 thousandths smaller but I got it in.  No pics of it installed because it was 11pm, I will get some another day.
          I drilled the hole in the differential larger to use a 1/2" bolt with a nut on the back rather than the casting threads.  I had to grind some on the casting to get the nut in there.
          The old bushing was a struggle even with the air chisel.  I didn't realize it had rubber on the outside of the outer sleeve.
          Back in action, I drove it to work today and it seems great.  Fun fact: the bolts holding the axles to the differential flange were all able to be removed by hand, yes I did not have to rotate the axles to get all 6, they were so loose I just reached around the axle and took them out with my fingers.  Pretty sweet.
            Nice job on the solid bushing. That bushing was one of the worst to get out when I refreshed the subframe on my coupe.
              Do you think the bolt snapped because it was loose?
              Like the new stainless steel bolt its shinny
                It is quite possible that it was loose the whole time.  I could not get the broken piece extracted though and ended up drilling it out completely.  I will replace the bolt with a grade 8 or 10 regular one, stainless looks cool but is not great as far as strength.  I did not measure how long I would need so I borrowed several from work to try.  We build food equipment so everything is SS.
                  Awesome. I love finding things like this after buying and driving for a few 100 miles. Your repair looks great!
                    I got the injectors, they look good but I haven't had time to install them yet.  I am trying to get my boat ready for sale to free up some cash for the barn/shop project.  Last night was one step forward and three backwards.  I was filling coolant (2 stage cooling on the Volvo Penta I/O setup) so I could test run it after replacing timing belt, water pump, seals, etc and it was leaking coolant out of the heat exchanger housing.  So I had to drain the coolant and remove the heat exchanger to split it and replace the gasket.  I broke 4 of the 14 screws off even with torching and tapping on them.  Darn that galvanic corrosion...  So I brought it to work with me to extract after work today.  Fun fun.
                      It looks like this, the red thing in front is the heat exchanger housing.  It has a brass plate type element inside that the raw water goes through with coolant surrounding it.
                      fetch?id=7165377
                        So the car has been driving great other than water filling up the cylinder 5 and 6 spark plug wells after a big rain.  It did it even with the beauty cover installed...  I guess I need to run the hose on it and watch where water is going.  the rubber ring that somewhat seals around the outside of the hole for the oil fill is missing so maybe the water is running onto the oil fill cap and then under the cover?  It seems far fetched but it happens pretty much every heavy rain storm.
                          Just saw the post about the boat heat exchanger. Where's the dislike button when you need it??
                          Different chassis, but, the "elephant trunk" drain on the e30 firewall is responsible for similar behavior on a 24v e30. Whatever collects in the rain tray needs to drain through the elephant trunk instead of dumping onto the valve cover
                            The boat is running great as of Saturday night, very late...  I had replaced the timing belt, engine water pump, seals on the front of the engine etc.  Then I couldn't get it to start, not even a pop.  So I installed the marine electric fuel pump that I had bought a while back, now I had fuel to the carb, still no start though.  So I took the carb apart and cleaned it, 44mm solex downdraft, it had some dirt in it but the jets looked good.  Still no start...  Double checked the timing belt because it drives the intermediate shaft for the distributor, everything lined up perfect.  I double checked the plug wires are installed correctly.  That looks great according to FSM.  I removed the distributor cap to see if I had somehow installed the rotor wrong, hmm it is not pointing to cylinder one when at TDC...  After rotating all of the plug wires clockwise one spot it runs perfect.  Apparently someone installed the distributor turned 90 degrees long ago and I never looked when disassembling it because it ran fine.  I learned my lesson on that lol.
                            Good thought on the drain.  It is probably clogged with leaves and junk.  I will check that tonight.
                              I checked it out at lunch time, the drain was totally clogged with rotten leaves and twigs.  The next rain storm will test if that fixed it.
                                Boat is sold!  More money for the shop!
                                I took the first long distance trip of the e36, 600 miles round trip to Road America last weekend for the Hawk vintage races, it exposed a few slight issues.  The bolts came loose on one exhaust flange to the catback, I will use locknuts next time.  I think the added heat blowing around under the car caused the fuel line to start leaking slightly at the pump, just enough to smell fuel and stop the car to unload the whole back seat to get a look.  A good reminder to replace the rubber fuel lines and pump/sender gasket rings.  And it was spreading oil everywhere causing an awesome burning smell, I thought it was coming from the transmission because I filled it before leaving but I figured out that it is engine oil leaking around the dipstick tube.  I didn't pull the dipstick yet but I am guessing the oring is junk or not even there.
                                On the upside I did not have any water in the spark plug holes after the last rain storm so the drain being plugged was causing the issue.  And I got 27 mpg driving to RA, calculated mpg not from OBC.  The OBC reads slightly more optimistic because the injectors flow a couple % more than it is calibrated for.
                                I am working on figuring out what to do to escape from the photobucket nightmare.  What a pain.
                                  Just driving it.  Hit 278k this weekend.  Other than my old truck this is our only car right now because the Volvo is all taken apart.  The rear tires rub a little when it's loaded with groceries and kids in the back!
                                    original rings, bearings, and valvetrain that you know of ?
                                      Your wife must be a saint.
                                        The vin tags match and it is so filthy that I am pretty sure it has never been opened.  I have some new cooling system parts to put in when I get time.  It does burn/leak a little oil.  Around a quart every 1500 miles I think.  No big deal.
                                        I know, she wanted me to work on the Volvo and get that sold before I fix her new van lol.  Her main problem with it is that the power steering works about 25% of the time so parking lots are tricky.  It's weird because sometimes it feels normal and other times there is no assist at all.  Maybe the relief valve is sticky?  It is better than when I first started driving it but still not great.
                                          That's not much different than my e36 with half the mileage, I'd say you're doing pretty well!
