  3. Parts Wanted
  4. WTB: 24V/M54 swap parts
58 Posts 12 Posters 0 Views 1 Watching
    S54 fuel pressure regulator housing on the way, list is getting shorter!
      Oil pan sourced. A lot of what is remaining could come from a manual 530i being parted out, let me know if you see one in a junkyard or being parted out!
        Bumping this up in case anyone comes across anything I need, list has been updated and is getting shorter!
        • TkuhnT
          TkuhnT
          Tkuhn
          Message me I may have the harness you need! Or text is easier!
          2626898043
            2626898043
            Sent you a PM!
              Differential acquired. List updated!
                What ratio did you get
                  3.15 lsd from a z3m coupe! didnt get the cool (pun intended) diff cover but that made it a lot more affordable haha
                  Sent from my SM-G920V using Tapatalk
                    List updated, deposit placed on an engine 😎
                      Ted's?
                        Ted's?
                        Yup! 120k on it with good compression test results (and its pretty local) so it fit exactly what I was looking for
                          List updated!
                            6b8c71ab9fdad57fa1dc8170459533c0.336x252
                              Im not keen on the going rates for MAFs but this is an OE unit  https://www.ebay.com/i/272885069168?chn=ps
                                Updated first post, found a gas pedal for cheap.
                                Thanks! I haven't shopped around on these yet since I don't need it right away, but that doesn't seem unreasonable for an OE one
                                  List updated:
                                  The DISA valve on my engine is not an OEM part and is shot, so I'm looking for an OEM one to rebuild.
                                    https://www.ebay.com/itm/BMW-M54-DISA-Valve-11617544805-7544805-E46-E39-E60-E61-E65-E66-X3-X5-Z3-Z4-OEM/172979174601?hash=item28465cbcc9:g:i-4AAOSwXxhaCjvI&vxp=mtr
                                      Some bits acquired, list updated!
                                        Added 325i coding plug for the tach
                                          If I find a spare cluster soon I will let you know. I wont need 2 coding plugs
