  3. Parts Wanted
  4. WTB: 24V/M54 swap parts
58 Posts 12 Posters 1.1k Views 2 Watching
  • Dominic540D
    Dominic540D
    Dominic540
    No problem! Just figured I'd throw it out there.
    Edit: Tried quoting your post to reply to it, won't work for whatever reason.
      Picking up a ZF trans thanks to DrLeadFoot!
        https://madison.craigslist.org/pts/d/bmw-limited-slip-diff/6236667953.html
        2.93 in madtown. price is high for that ratio, IMO, but maybe you can talk him down.
          Hadn't seen that, thanks for the tip! I did some thinking/research on ratio's and based on my intended use of the car I think a 3.23/3.25 will be the best for what I want, so I'm going to hold out for one of those
            Who knows, maybe after i'm up and running I will want a nice S3.73 to replace my S3.25. You are welcome to pit maneuver me for it
              S54 fuel pressure regulator housing on the way, list is getting shorter!
                Oil pan sourced. A lot of what is remaining could come from a manual 530i being parted out, let me know if you see one in a junkyard or being parted out!
                  Bumping this up in case anyone comes across anything I need, list has been updated and is getting shorter!
                  • TkuhnT
                    TkuhnT
                    Tkuhn
                    Message me I may have the harness you need! Or text is easier!
                    2626898043
                      2626898043
                      Sent you a PM!
                        Differential acquired. List updated!
                          What ratio did you get
                            3.15 lsd from a z3m coupe! didnt get the cool (pun intended) diff cover but that made it a lot more affordable haha
                            Sent from my SM-G920V using Tapatalk
                              List updated, deposit placed on an engine 😎
                                Ted's?
                                  Ted's?
                                  Yup! 120k on it with good compression test results (and its pretty local) so it fit exactly what I was looking for
                                    List updated!
                                      6b8c71ab9fdad57fa1dc8170459533c0.336x252
                                        Im not keen on the going rates for MAFs but this is an OE unit  https://www.ebay.com/i/272885069168?chn=ps
                                          Updated first post, found a gas pedal for cheap.
                                          Thanks! I haven't shopped around on these yet since I don't need it right away, but that doesn't seem unreasonable for an OE one
