WTB: 24V/M54 swap parts
No problem! Just figured I'd throw it out there.
Edit: Tried quoting your post to reply to it, won't work for whatever reason.
https://madison.craigslist.org/pts/d/bmw-limited-slip-diff/6236667953.html
2.93 in madtown. price is high for that ratio, IMO, but maybe you can talk him down.
Hadn't seen that, thanks for the tip! I did some thinking/research on ratio's and based on my intended use of the car I think a 3.23/3.25 will be the best for what I want, so I'm going to hold out for one of those
Message me I may have the harness you need! Or text is easier!Â
2626898043
Sent you a PM!
What ratio did you get
3.15 lsd from a z3m coupe! didnt get the cool (pun intended) diff cover but that made it a lot more affordable haha
Sent from my SM-G920V using Tapatalk
Ted's?
Yup! 120k on it with good compression test results (and its pretty local) so it fit exactly what I was looking for
