    That's the first time i've seen a pick of one installed or compared to the 7" and OEM.  That's fucking massive!  Did you happen to check your coolant temps before and after to see if they were affected negatively from this?
      Holy toast! Thanks for posting the before and after info, very fascinating!
        I just checked water temperature on both of the logs and it's exactly the same. 10° rise with both intercoolers during the same pull.
          That's awesome!  That thing is definitely not stealthy by any means.  Although I think you threw the sleeper image out of the window a long time ago that giant front mount isn't fooling anyone.
            It is still a 1 series.  Still cute by anyones measure.  Like the LS Miata.....still a miata, lol.
              170, 170, 80, 170, 170, 170. I blame this forum and won't ever be returning.
              • JeffJ
                JeffJ
                Jeff
                I think you should be blaming snap for this epidemic.
                All votes for snaps banning say aye.....
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  Really sorry to hear this news!
                    When you do a compression test there is two possible results good or wibimmers.
                        That sucks.
                        If possible, check that the valves are seating before tearing the head off/pulling the motor. Could be something dumb like a broken lock/retainer ring/piece of something stuck in there/etc.
                          Carbon
                            Super bummer man. Like HipMF said, check everything before claiming sudden death.
                              That sucks.
                              Did a wet test. Tablespoon of oil boosted compression from 80 to 120psi. I'm 99.9% sure it's a ring or ringland. Leakdown and borescope this week.
                                That would definitely indicate a ring problem.  Easy fix if the cylinder walls are fine!  Fingers crossed!
                                  I don't know if "easy" is the right word, lol. Getting in there to replace a piston isn't a walk in the park.
                                    It books as a 30+ hr job.  It's time consuming but easy.  Especially when you consider the cost of a used engine... much easier on the wallet.  Just get Paul to "help" lol.
                                      In contrast, r&r engine is about 28 book hours.
                                      • IceddragonI
                                        IceddragonI
                                        Iceddragon
                                        Pardon my ignorance, what exactly happened with this? What did those numbers mean? I'm assuming cylinder pressure?
                                        I love this build and you guys sound like its dead 😦
                                        • JeffJ
                                          JeffJ
                                          Jeff
                                          Its crazy how long shop times are sometimes.
                                          1976 530i e12
                                          1990 325ix e30
                                          1992 325i e36
                                          1995 740il e38
                                          2001 330xi e46
                                          ^More to come :)
