    Daggerty said:
    When you do a compression test there is two possible results good or wibimmers.
      That sucks.
      If possible, check that the valves are seating before tearing the head off/pulling the motor. Could be something dumb like a broken lock/retainer ring/piece of something stuck in there/etc.
        Carbon
          Super bummer man. Like HipMF said, check everything before claiming sudden death.
            That sucks.
            Did a wet test. Tablespoon of oil boosted compression from 80 to 120psi. I'm 99.9% sure it's a ring or ringland. Leakdown and borescope this week.
              That would definitely indicate a ring problem.  Easy fix if the cylinder walls are fine!  Fingers crossed!
                I don't know if "easy" is the right word, lol. Getting in there to replace a piston isn't a walk in the park.
                  It books as a 30+ hr job.  It's time consuming but easy.  Especially when you consider the cost of a used engine... much easier on the wallet.  Just get Paul to "help" lol.
                    In contrast, r&r engine is about 28 book hours.
                    • IceddragonI
                      IceddragonI
                      Iceddragon
                      Pardon my ignorance, what exactly happened with this? What did those numbers mean? I'm assuming cylinder pressure?
                      I love this build and you guys sound like its dead 😦
                      • JeffJ
                        JeffJ
                        Jeff
                        Its crazy how long shop times are sometimes.
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          Not to sidetrack the thread but yes.  Honestly they UNDER estimate a lot of this shit.  They don't take rust and wear into consideration.
                          • i_love_carsI
                            i_love_carsI
                            i_love_cars
                            just get a used motor. It's gonna cost you $1500 in parts to do a full rebuild which is the only acceptable answer if you are tearing down the engine in the first place. You're not just gonna replace 1 ring or 1 piston. You're gonna do a complete overhaul including pistons. Then you need to make sure you do it right, and whether or not you did it right becomes far more obvious when you're making +350 whp/tq over factory power. So you'll be spending a lot of time here. The engine has too many miles on it to NOT overhaul everything if you tear it down.
                            you need to pull the motor regardless, so factoring in what your time is worth, you'll have a lot of hours into a teardown/rebuild on top of pulling/reinstalling the motor. Considering a used motor with less than half the miles on your current engine can be had for $3k and it's a straight swap, I wouldn't even be considering a rebuild. N54 motors are a commodity. When you grenade one, you just go get a used one and replace it. That's just what you do. This isn't an old M50 or something where finding good used examples is hard to do and you have to be more serious about rebuilding (plus parts are way cheaper for those anyway). I can throw a rock out the window and hit 5 n54 motors on the used market within walking distance of my bathroom all with 50k miles on them.
                            2007 Z4MR
                            2003 E39 M5
                            2002 E46 M3
                            2021 X5 40i
                              Why do you have rocks in your bathroom?
                                It lost compression on cylinder #3, motor is constantly misfiring and running rough. Needs to be repaired internally or replaced.
                                Chances are, it's gonna be a while until the car is back on the road. I don't have the funds.
                                True, but to be fair, I bet this is accurate. I spent a lot of time replacing the turbos and would assume pulling the motor and re-installing it would probably take awhile.
                                I'm fully aware of the situation I'm in. Problem is, I don't have the funds.
                                Care to share links to motors in WI with less than 50k miles? I've found a couple for ~$2500, but this was the lowest mileage one I could find locally.
                                http://bayauto.com/used-parts/BMW/BMW_335I/BH0380/2007/Engine_Assembly/1001605770
                                • i_love_carsI
                                  i_love_carsI
                                  i_love_cars
                                  It was a general point about how easy it is to locate used N54 motors and I was trying to bring humor to a shitty situation. Not that I literally know of super low mileage motors within a short radius to us here in WI.
                                  I was thinking something like this:
                                  http://www.ebay.com/itm/BMW-135i-335i-3-0L-Twin-Turbo-Engine-Motor-Dropout-Free-Shipping-71k/152663897833?epid=874569161&fits=Make%3ABMW|Model%3A335i&hash=item238b7a36e9%3Ag%3AlPkAAOSwj8JZkiEC
                                  Comes with turbos and other components. You could part some of that out and have the motor for less than $2k easily when all is said and done.
                                  2007 Z4MR
                                  2003 E39 M5
                                  2002 E46 M3
                                  2021 X5 40i
                                    That's a great example. Good price, lower miles, and comes with crap I can sell.
                                    To take out another credit card or not... 😒
                                      This might sound out there but check with Advance Auto if you have one nearby.  They work with a network of auto recyclers and might be able to find something for you.
                                        Really? How would I even begin to start this conversation? Lol.
                                        • i_love_carsI
                                          i_love_carsI
                                          i_love_cars
                                          "are you guys able to source used/refurbished engines for my 2008 BMW 135i? "
                                          2007 Z4MR
                                          2003 E39 M5
                                          2002 E46 M3
                                          2021 X5 40i
