    Hell yes!! I want a ride in this thing!
    Did you have to pull the whole intake manifold back off when you realized you forgot that plug on the end of the secondary fuel rail?
      Congrats on not dying from the fuel hazards, also congrats on not dying from whatever power level you are at [emoji1319]
        I hope to have it at that meet this fall, maybe then!
        And no, I didn't. Luckily I was able to snake my hand back there and tighten it.
        Congrats on not dying from the fuel hazards, also congrats on not dying from whatever power level you are at emoji1319.png
        Thanks! I'd like to strap it on the dyno sometime in September.
          Very cool system.  Is it a returnless?  Maybe a better way to ask this, is the car returnless stock?  if so, does this add a return line?
            These cars come stock with a returnless fuel system. I didn't add a regulator or return line with this upgrade, that's the next level up as seen here.
              OK, makes sense.  I wonder how they plumb the return line in.  It's been something I've been scratching my head on with mine for awhile.
                My new intercooler came in last week and I was able to tackle the job yesterday. Let's first compare intercoolers. Stock vs. VRSF 7" vs. VRSF 7.5" Race intercooler.
                Definitely larger and definitely heavier. Let's take a closer look at the fin density and cooling bar size.
                Old intercooler:
                New intercooler:
                Much better 😄 now let's get this thing in the car!
                It required A LOT of cutting and trimming.
                I thought this would be enough, but I was wrong. I had to cut even more before I could stuff this intercooler up in there.
                Now that it's in, does it blend work?
                My previous intercooler saw a 54° rise in intake temperature during a 28psi 60-130mph pull. The new intercooler only rose 5° during a similar pull with similar ambient temp. See light blue line on my logs.
                Before:
                After:
                Overall, very happy with the results! One step closer to hauling ass.
                  Wow that's a huge improvement!
                    That's the first time i've seen a pick of one installed or compared to the 7" and OEM.  That's fucking massive!  Did you happen to check your coolant temps before and after to see if they were affected negatively from this?
                      Holy toast! Thanks for posting the before and after info, very fascinating!
                        I just checked water temperature on both of the logs and it's exactly the same. 10° rise with both intercoolers during the same pull.
                          That's awesome!  That thing is definitely not stealthy by any means.  Although I think you threw the sleeper image out of the window a long time ago that giant front mount isn't fooling anyone.
                            It is still a 1 series.  Still cute by anyones measure.  Like the LS Miata.....still a miata, lol.
                              170, 170, 80, 170, 170, 170. I blame this forum and won't ever be returning.
                              • JeffJ
                                JeffJ
                                Jeff
                                I think you should be blaming snap for this epidemic.
                                All votes for snaps banning say aye.....
                                1976 530i e12
                                1990 325ix e30
                                1992 325i e36
                                1995 740il e38
                                2001 330xi e46
                                ^More to come :)
                                  Really sorry to hear this news!
                                    When you do a compression test there is two possible results good or wibimmers.
                                        That sucks.
                                        If possible, check that the valves are seating before tearing the head off/pulling the motor. Could be something dumb like a broken lock/retainer ring/piece of something stuck in there/etc.
                                          Carbon
