  4. E30 M52
E30 M52
    Why not just get an OBD1 timing cover and avoid the JB welding massacre that will be installing the coolant pipe.
    Unless that won't work
      Im only removing them to check the chain guides, replace the seals, and clean them up. The covers should be milled with the head/block to keep from being too high/low so i will keep these since they match the engine
        Re-RTV that shiz
          Black rtv on anything that touches oil, gray rtv on anything that touches coolant, copper rtv on anything that touches exhaust. Always and forever
          • JeffJ
            JeffJ
            Jeff
            JB weld on everything remaining?
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
              Things a significant other said today:
              "Why do you have to clean everything???"
              The slow progress, the cleaning, the painting , the toaster quality photos, and all the pointless updates continue...
                If anybody in my area has experience with 24V cam removal/install/timing I invite you to join me on a magical cam replacement adventure this weekend.
                This is your invitation.
                • JeffJ
                  JeffJ
                  Jeff
                  You have no date posted for said event...
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                    Or time...
                    Not that I don't have things that I can do, but I'm kind of playing the waiting-on-parts game at the moment.
                    Also, I actually don't have any experience with 24v things, but I'll be happy to tell you what you've done wrong after something breaks.
                      I can vouch for his qualifications in this area.
                      10/10 would recommend
                        I could help you Tuesday or Wednesday.
                          Exhaust studs installed, passenger side of engine cleaned and painted. On to the cams now.
                          Dom I may take you up on your offer. I will let you know
                            I spent all my cam install time today scrubbing my garage floor with some concrete cleaner. Lets just say yesterday I earned an Oil-Dri sponsorship for my accurate scale depiction of the BP Gulf oil spill.
                            I also discovered the E36 oil pan on this engine (which i'm not using) is cracked so that saves me from having to try selling it.
                            My vamos rebuild starts with a gross negligence towards following instructions and a blatant disregard for left handed threads so I snapped the torx screw inside the deep bore of the helical gear. Unrepairable.
                            This is the helical gear
                            I didnt want to curse my vamos by getting my Dora gloves all dirty but unfortunately oil on precision machined aluminum is very slippery and the vamos piston got away from me.
                            I couldnt quite get a good grip so I used some vise-grips, but the handles were oily so I dropped it again.
                            So the broken screw really happened but luckily i had a spare vamos assembly to pick parts from so no usable vamos parts were harmed in this rebuild.
                            I installed the Beisan. Its spelled Beisan, not BeSian, Beisan, like Nissan. Just like how its a Giubo and not a Guibo, and a vamos instead of a vanos, wait, dammit!
                            The Beisan anti rattle ring was installed and the piston seals were replaced. Its nice and tight now. Just hope it all works.
                              Sweet gloves.
                                More unbelievable progress:
                                VANOS solenoid got a makeover and its o-ring replaced. WOW.
                                  Get a new cam sensor oring. I forgot to replace mine. Healthy dose of rtv and way-too-small oring for the "fix"
                                    Making lots of progress on something we all thought we wouldn't see. I really enjoy your posts, informative and yet hilarious.
                                      Primary cam sprockets have been removed. Chain tensioner guides are groovy and will be replaced. Lower chain guides are broken/ disintegrating and will be replaced.
                                      Someone has been in here before and had the sprockets off. The vanos seals were brittle so it wasnt for a vanos rebuild, the guides are plenty worn so it wasnt for that. So I would assume the head gasket has been replaced or something.
                                      I could be sitting on a fresh BMW head gasket.
                                      or
                                      the engine could have overheated, they slapped on a 284k mile head with a Fail-Pro gasket and reused the head bolts.
                                      who really knows.
                                      I need to get my oil pan and baffle dropped off for welding so it is ready to go on in the near future.
                                        Crazy how the guides were blasted already.
                                          Can you see the corner of the head gasket?  It should stick out in one spot so you can see what it is if it isn't too crusty.
