  4. E30 M52
E30 M52
    Tonight I installed the rear main seal into its carrier, protruding 1.5mm. I will wait until I install the E34 oil pan to install the carrier/seal onto the block.
    Out of my own curiosity, I wanted to overlay all the BMW 2.5L engines: M20B25, M50NV, M50TU, M52B25, M54B25, N52B25 and see how the torque curve flattened over time with all the technology advancements. Instead I lost interest and threw the modded M52 data over some data for
    a stock M20B25 vs. an M52B28, M50 manifold, S52 cams, intake, exhaust, stock ex. manifolds, and tune.
    I remember having fun with my stock M20 so it appears there is a little more fun in store with the M52. Next week will for sure see some significant progress as I will have some extra time, but I will keep nibbling away at things this week like I have been doing.
      When the vanos hits!!  In all seriousness though it is interesting that the the hp and torque curves have a similar profile between the two engines.
        I noticed that as well. The M50 manifold and S52 cams sacrifice the low end, but definitely make up for it in the higher revs
          Hello turd.
          Last night I replaced the clutch hardline that had rounded hardware, scrubbed the engine bay, and cut off the intercooler mounts I had welded on.
          Tonight: more scrubbing and paint touchup in the engine bay. Nothing worth taking pictures of, but all necessary tasks to make me feel some level of satisfaction with my efforts.
            "You'll never get the crank bolt without the locking pin or at least the engine in the car"
            "Nobody ever gets the jesus bolt loose at home, its red-loctited from the factory"
            "Harbor freight tools are garbage"
            "Electric impact guns are inferior to a traditional air impact"
            Rubbish.
            This is the 4th BMW crank bolt I have removed with this 6 year old HF electric impact gun.
              And that same impact got my rear axle nuts loose on my trailing arms after they were already off the car. *thumbs up*
                Why not just get an OBD1 timing cover and avoid the JB welding massacre that will be installing the coolant pipe.
                Unless that won't work
                  Im only removing them to check the chain guides, replace the seals, and clean them up. The covers should be milled with the head/block to keep from being too high/low so i will keep these since they match the engine
                    Re-RTV that shiz
                      Black rtv on anything that touches oil, gray rtv on anything that touches coolant, copper rtv on anything that touches exhaust. Always and forever
                      • JeffJ
                        JeffJ
                        Jeff
                        JB weld on everything remaining?
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          Things a significant other said today:
                          "Why do you have to clean everything???"
                          The slow progress, the cleaning, the painting , the toaster quality photos, and all the pointless updates continue...
                            If anybody in my area has experience with 24V cam removal/install/timing I invite you to join me on a magical cam replacement adventure this weekend.
                            This is your invitation.
                            • JeffJ
                              JeffJ
                              Jeff
                              You have no date posted for said event...
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                Or time...
                                Not that I don't have things that I can do, but I'm kind of playing the waiting-on-parts game at the moment.
                                Also, I actually don't have any experience with 24v things, but I'll be happy to tell you what you've done wrong after something breaks.
                                  I can vouch for his qualifications in this area.
                                  10/10 would recommend
                                    I could help you Tuesday or Wednesday.
                                      Exhaust studs installed, passenger side of engine cleaned and painted. On to the cams now.
                                      Dom I may take you up on your offer. I will let you know
                                        I spent all my cam install time today scrubbing my garage floor with some concrete cleaner. Lets just say yesterday I earned an Oil-Dri sponsorship for my accurate scale depiction of the BP Gulf oil spill.
                                        I also discovered the E36 oil pan on this engine (which i'm not using) is cracked so that saves me from having to try selling it.
                                        My vamos rebuild starts with a gross negligence towards following instructions and a blatant disregard for left handed threads so I snapped the torx screw inside the deep bore of the helical gear. Unrepairable.
                                        This is the helical gear
                                        I didnt want to curse my vamos by getting my Dora gloves all dirty but unfortunately oil on precision machined aluminum is very slippery and the vamos piston got away from me.
                                        I couldnt quite get a good grip so I used some vise-grips, but the handles were oily so I dropped it again.
                                        So the broken screw really happened but luckily i had a spare vamos assembly to pick parts from so no usable vamos parts were harmed in this rebuild.
                                        I installed the Beisan. Its spelled Beisan, not BeSian, Beisan, like Nissan. Just like how its a Giubo and not a Guibo, and a vamos instead of a vanos, wait, dammit!
                                        The Beisan anti rattle ring was installed and the piston seals were replaced. Its nice and tight now. Just hope it all works.
                                          Sweet gloves.
