  4. E30 M52
E30 M52
    Also, I actually don't have any experience with 24v things, but I'll be happy to tell you what you've done wrong after something breaks.
    I can vouch for his qualifications in this area.
    10/10 would recommend
      I could help you Tuesday or Wednesday.
        Exhaust studs installed, passenger side of engine cleaned and painted. On to the cams now.
        Dom I may take you up on your offer. I will let you know
          I spent all my cam install time today scrubbing my garage floor with some concrete cleaner. Lets just say yesterday I earned an Oil-Dri sponsorship for my accurate scale depiction of the BP Gulf oil spill.
          I also discovered the E36 oil pan on this engine (which i'm not using) is cracked so that saves me from having to try selling it.
          My vamos rebuild starts with a gross negligence towards following instructions and a blatant disregard for left handed threads so I snapped the torx screw inside the deep bore of the helical gear. Unrepairable.
          This is the helical gear
          I didnt want to curse my vamos by getting my Dora gloves all dirty but unfortunately oil on precision machined aluminum is very slippery and the vamos piston got away from me.
          I couldnt quite get a good grip so I used some vise-grips, but the handles were oily so I dropped it again.
          So the broken screw really happened but luckily i had a spare vamos assembly to pick parts from so no usable vamos parts were harmed in this rebuild.
          I installed the Beisan. Its spelled Beisan, not BeSian, Beisan, like Nissan. Just like how its a Giubo and not a Guibo, and a vamos instead of a vanos, wait, dammit!
          The Beisan anti rattle ring was installed and the piston seals were replaced. Its nice and tight now. Just hope it all works.
            Sweet gloves.
              More unbelievable progress:
              VANOS solenoid got a makeover and its o-ring replaced. WOW.
                Get a new cam sensor oring. I forgot to replace mine. Healthy dose of rtv and way-too-small oring for the "fix"
                  Making lots of progress on something we all thought we wouldn't see. I really enjoy your posts, informative and yet hilarious.
                    Primary cam sprockets have been removed. Chain tensioner guides are groovy and will be replaced. Lower chain guides are broken/ disintegrating and will be replaced.
                    Someone has been in here before and had the sprockets off. The vanos seals were brittle so it wasnt for a vanos rebuild, the guides are plenty worn so it wasnt for that. So I would assume the head gasket has been replaced or something.
                    I could be sitting on a fresh BMW head gasket.
                    or
                    the engine could have overheated, they slapped on a 284k mile head with a Fail-Pro gasket and reused the head bolts.
                    who really knows.
                    I need to get my oil pan and baffle dropped off for welding so it is ready to go on in the near future.
                      Crazy how the guides were blasted already.
                        Can you see the corner of the head gasket?  It should stick out in one spot so you can see what it is if it isn't too crusty.
                          Cams removed, they didnt break. Now to achieve the same success installing the S52 cams.
                          Probably Saturday
                            The first time is the worst. So the story goes.
                              Journals in good shape?
                                Yeah, nothing to see there
                                  Ball
                                  Sacks
                                  Intake cam is in but while torquing the bearing caps to 15 Nm two of the studs pulled out
                                  I can only imagine the horror people feel as they torque head bolts into an aluminum block and feel it give way.
                                  Not the end of the world at all but I will have to remove the cam and trays/lifters to helicoil them.
                                  Minor annoyance. Not the progress I was hoping for today though
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    Ouch man what a kick in the nuts
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                      1000x better than breaking a camshaft though. I'll take it.
                                        Odd that the head-side went. You'd think the stud would be bottomed out and the nut wouldn't turn it anymore.
                                        But as you said. 100000 times better than a cam
                                        • JeffJ
                                          JeffJ
                                          Jeff
                                          But see now your doubling your chances at breaking it so that would be -1000x. We both know that will just cancel it self out now and create the crazy looking number "0"
                                          Practice makes perfect?
                                          1976 530i e12
                                          1990 325ix e30
                                          1992 325i e36
                                          1995 740il e38
                                          2001 330xi e46
                                          ^More to come :)
