  4. Hello. My name is Matt, and I like spending money
bmwe30325isedanalpine
32 Posts 10 Posters 596 Views 1 Watching
    If he is sending it where I think he is, the Texas shop is absolutely killer and their pricing is incredible=P
    http://www.driveshaftspecialist.com/Import html/BMW.html
    • MattYM
      MattYM
      MattY
      Yeah, a lot of people have recommended their service to me so I thought I'd take advantage.
      Also that car was at Schmidt's, they don't charge extra labor for moving stuff but they make you pre pay for the part you need pulled. They told me $100 for the driveshaft and $300 for the LSD, so I hopped right on that.
        I wish I would have seen that you were having a driveshaft rebuilt. I have one sitting in the shop that I would have sold you for half of what you paid.
          But does it have a fresh black paint job?
            No, but it would have been a half priced core to send in to be rebuilt.
            • MattYM
              MattYM
              MattY
              my bad, i should've specified earlier!
              • MattYM
                MattYM
                MattY
                chris keeps bitching at me to update this thread even though the only thing i've done is spend money on parts.
                Just received my RHD M20 flywheel, looking shiny as ever:
                Using this guy alongside a brand new sachs kit from ECS. i REALLY like the stock e30 clutch so this should be amazing. also ordered a hydraulic alternator tensioner, aluminum thermostat housing, and completed my short shift setup with a turner shift arm bracket and a zhp knob. Stage one of the project is essentially getting the M50 reliability upgrades in, redo gaskets, and assembling the trans and shifter to get it all ready to drop in at once.
                also i started assembling the weds. will be running these on the calypso for the time being, they'll be mounted shortly. bask in their glory:
                  weds upside down is spam. you should tell people they are spam wheels.
                    Thanks Dan now I'll never unsee that haha
                      Its already been done Matt. Better throw in the towel now before you spend more money.
                      • MattYM
                        MattYM
                        MattY
                        another alpine sedan?? i'm out boys cya
                          With the Spam shoes.
                          • MattYM
                            MattYM
                            MattY
                            real talk though i'll stop shitting up the group chat and get my m50(b25tu) maintenance sorted out here.
                            currently todo:
                            • head gasket
                            • vanos seals, rattle repair kit (besians)
                            • thermostat housing replacement
                            • hydraulic alternator tensioner conversion
                            • upgraded oil pump shaft (achilles)
                            • reinforce oil pick-up (also achilles)
                            thermostat and water pump / pulley are replaced already.
                            am i missing anything big? motor has 140-160 on it iirc
                                Which trans are you using? I see the M20 flywheel. I am still extremely skeptical about all this nonsense people spout off online about the M20 flywheel hitting the block. Im not seeing it.
                                I see the upgraded oil pickup tube. Are you using a rear-sump oil pan?
                                • MattYM
                                  MattYM
                                  MattY
                                  G260 with the sachs m20 clutch kit (https://www.ecstuning.com/b-sachs-parts/clutch-kit/21211223102~sac/), I've got the trans brace from ben already.
                                  i have an e34 oil pan but i personally wouldn't know if that's rear sump, haven't ordered the oil pump parts so no worries if I screwed up.
                                    E34 is front sump, all others are rear sump
                                    • MattYM
                                      MattYM
                                      MattY
                                      on the bright side, looks like ya boy here gets to save $60. should i be okay with just the oil pump upgrade?
                                        Yes
