580 Posts 27 Posters 0 Views 1 Watching
    Amazing
      Love the apex everything decal. Great shots and beautiful car!
        Wow, very nice shots! 2nd one is my favorite. We really need to take more nice photos with the group.
          Those look good. Daily as not in the winter though.....
            Beautiful E30!
              thanks, dudes!
              i agree. wish it had not been raining saturday so the camera could have come out.
              no, not if I can help it. but i also don't have indoor storage, so that doesn't help the cause.
                Came*** here just for this shot. Very very nice man!
                  CABs switch to solid lollipops today, as well as a new shifter bushing.
                  having the passenger side CAB not resting on my exhaust reduced some cabin noise as expected. i still do have an odd rattle when starting from a stop in that same area that I thought would have been the exhaust, but it did not go away. *shrug*
                  also, first road trip with the car this weekend. time for some backroad blasting :D
                    Last time I touched the control arms was 7 years ago. Did you need a tool to get the old bushings off/new ones on?
                    I definitely had to make a tool from threaded rod to get the bushings on the last time
                    Coincidentally I ordered some from Garigistic today
                      What engine mounts do you have dan?
                        I was just barely able to get the old bushings pulled from the arms with a 3-jaw gear puller. They were already offset bushings so I had to use unequal length arms on the puller and drill a hole in the end of the control arm to keep the threaded rod from traveling off.
                        Engine mounts are r3vshift
                          did some work on both cars today.
                          scored a sweet e28 mtech I spoiler already in alpine from andy - thanks dude.
                          new holes drilled
                          the center 4 holes are close enough to the stock locations that access from inside the trunk lid is easy
                          however, the outside two are much wider, so cutting the openings inside the trunk lid is necessary to get the nuts on there.
                          and voila!
                          had the same setup on my last e30 and loved it. photo circa 2012
                          on my roadtrip up north last weekend, some dickweed trailering a boat left stuff in the boat (life jackets, fishing poles, etc) while traveling on the freeway, and they proceeded to jettison while I was driving behind him. it cost me a high beam lens and some scratches. ordered a replacement DEPO set to get parts off and installed them.
                          i also deactivated the bumper running lights and hooked up my amber LEDs that I installed into the low beams when doing my retrofit.  here is the result:
                          last step is to get the fogs working independently
                            Glad to see that spoiler made it onto your car! Looks really good. Can't complain about the color match.
                              Glad the jettisoned cargo didnt take out the fresh paint on the valence. I really like what you did with the amber lights. I remember the slick LED signal setup you did on your black car from long ago too.
                              • MattYM
                                MattYM
                                MattY
                                that's a sweet rear look. i'm tempted to run an mtech ii wing on mine if i can source one, cause the price to paint an IS spoiler in alpine would probably be close enough where i wouldn't hate myself for shelling out for the mtech
                                  just paint it yourself. $40 for a BMW color-matched spray can and a little time on prep work. super easy.
                                  i have a spare 'i' spoiler now that needs some sanding/scraping of old paint that you can just have.
                                    Damn. All kinds of awesome in here. Looks great Dan!
                                      Somehow managed to get a couple months behind on this thread. Nice work. The "palamino"/alpine combo is awesome!
                                      • MattYM
                                        MattYM
                                        MattY
                                        that would be sweet! i'm gonna have to get my valance painted, so might as well redo the skirts and that spoiler as well.
                                          got some stuffs fixed.
                                          had a slight rattle on acceleration from low speed, which turned into a major rattle. i figured the CSB was dead, but never expected this would be why:
                                          not sure what car this wimpy CSB is from, but i replaced it with the correct e30 one. getting the length/alignment right on the bench:
                                          so I've had three small issues with the shifter since I bought the car and decided to tackle them while the driveshaft was out.
                                          first was a bunch of right-left slop with the car in gear. I found the selector joint was super wobbly. seems the PO lost the pin and decided to do a hack job and make his own. (see bottom pin) i made a correctly fitting one (see top pin)
                                          new joint
                                          i also found a second, equally ?wtf? hack. this was how the rear of the carrier was mounted to the car...
                                          i purchased the turner rear poly carrier bracket, as its the same price as the rubber OEM piece. you can see it barely in the picture of the whole shift setup down below.
                                          https://www.turnermotorsport.com/p-392619-turner-shifter-bushing-assembly-e28-e30-e34/
                                          so the second issue with the shifter setup is that the stock e30 carrier places the shifter way off center and forward in the trans tunnel with the s50/e36 zf. i was unable to install a new rubber boot due to this and as well, 5th gear was so far up to the right it would barely contact the shift boot/console edge.
                                          here's the original location:
                                          so the solution is a new carrier. a dude over on r3v found that an e46 version worked well if you cut it shorter, so I ordered one up.
                                          e30 on the bottom, e46 on the top.
                                          you can see it offsets a bit more to the centerline as well as towards the back of the car (once cut to the right length)
                                          measure twice, cut once. er cut twice.
                                          some bolts/c-channel made quick work of putting it back together.
                                          well, i didn't consider that lengthening the carrier that much would cause an issue with the length of the dssr, and it did. with the length shown above, the shifter was tilted super far back when in neutral, so I took another 3/8" of length out to make it work perfectly.
                                          here's the entire setup back together. you can just barely see the turner carrier bracket here. everything is nice and tight now. :shifty:
                                          not as far back as I wanted, but I can get the rubber boot on now.
                                          my third issue was the 'irremovable' shift knob. see this post for my struggles:
                                          anyways, the PO glued the shift knob to the shift lever, so bye bye beautiful zhp knob.
                                          removal:
                                          Garagistic has an awesome old-school look knob that is weighted (heavier than the zhp). it also only happens to be $25
                                          https://store.garagistic.com/OEM-BMW-parts/e30-e24-e28-weight-shift-knob-25111434495
                                          done and done.
                                          this picture is for brian. rear muffler is unbranded, unfortunately. pipes are 2". 'Resonators' are Thrush glasspack mufflers. i'd actually like to install another pair of them, they did wonders to the tone/rasp and i bet it would mellow it even more.
