    these:
    https://www.ecstuning.com/b-ecs-parts/heavy-duty-rear-shock-mount-reinforcement-plate-set/002478ecs01kt/?gclid=CIbVlPuowNMCFdgDgQodu08Drw
      Definitely don't want to tear those rear shock mounts. I love you Ground Control rsm's=P
        this.
        small update from the body shop guys.
        fyi, going with no "rock guard" on the front valance. should be purty.
          Gonna be sweet=)
            Noooice. Cant wait to see it painted.
              now, the real question is when am I going to get a phone call from the body shop because they cant get the coolant bled right? #swapcarproblems
                Looks like its coming along really well!
                  Thatll be a fun call lol
                    What body shop are you using?
                      car is back from body work. the shop I used was Authentic Automotive. I give them a 7/10. They left my new carpet dirty as hell from their shop boots :rolleyes: so now I have to clean it, and (per my odometer) they drove the car 3 miles, and they had no reason to need to drive the car off their lot, so...
                      core support straightened and valance installed/painted.
                      got my spal fan installed. hooked up to run constantly on ignition, will have to figure out wiring to temp switch or a dash switch at some point.
                      front end put together.
                      i also got the rocker panels repainted, wheels installed, and rear suspension set to the right height. a bonus is that the 16" wheels/225 tires ride softer than the snow tire setup. i'm guessing its the cheap Nexen tires having squishy side walls. the car handles still handles very neutral with a bit of throttle oversteer. :)
                        Looks so good in the pictures.
                          Wow! Looks great!
                          White>Black any day.
                          I know that sounds wrong but its okay because I own a Black.
                          Im upset that they drove it though[emoji58]
                            Maybe to re bleed the cooling system? And do a burnout maybe
                              It's hard to find good, honest shops for anything which is why I was curious for when mine gets painted. Yours looks damn good!!
                                Verifying the cooling system is bled is a legit reason to put a couple miles on the car.
                                  If it was a rusted out Chevy cruze LTZ+ do you think they would've taken it for a test drive?
                                    Looks great. White cars rule. If there was no damage done in the 3 miles it moved I wouldn't question it, probably just stoked to have an E30 in their shop. 😄
                                      uh oh. just got home, smelled some coolant in the last mile and the temp gauge was above half. #saturdayinjeapardy
                                        Ask Ben if you can borrow his temp gun
                                          Is that coolant spritzed all over there? Heater hose spring a leak?
